928 Forum 1978-1995
Sponsored by: 928 Specialists
Supercharger installations
Old Jan 21, 2003 | 07:24 PM
Koenig928's Avatar
Koenig928
Post
elemental,
Thanks for the Albrex link. It has been hard to find any info at all for my Albrex charger. Wish I had found it earlier. That picture of the 32v engine is the exact set up on my car.
Would be glad to answer any questions. I do not know anything about the Gruber kit, but am familiar with the Albrex charger setup now. I have disassembled the entire front of my motor (see post above) and found a few interesting things.
Cheers.
Old Jan 21, 2003 | 09:08 PM
Tim Murphy's Avatar
Tim Murphy
Post
The last picture in "Z's" oringinal post is my car without the intercooler. The oil stain on the hood liner is a result of a failed attempt at a temporary crank breather setup while I was at the track. If I remember right, the car made 410rwhp 401tq that day.
Old Jan 22, 2003 | 09:29 AM
elemental's Avatar
elemental
Post
Bill
No worries, I was pleased to find the link myself, because my mechanic mentioned an albrex charged s4 here, (which makes it easier for subsequent conversions to be type approved by the state mechanics <img border="0" title="" alt="[Wink]" src="wink.gif" />
I'd never heard of them and found nothing because I understood 'albrechts' - trying to be too smart...
I'd like to know what other load parts on the engine/transmission have become noticeably stressed with time on your lovely vehicle. It's probably one of the most 'experienced' blown-shark? It looks like 'solid' kit, is it? Have you dynoed it?
And of course, as you also own a 87 s4, is the blower worth it?
Cheers
Old Jan 22, 2003 | 10:26 AM
Jim Nowak's Avatar
Jim Nowak
Post
I looked at the Albrex web site but it doesn't give any specifics about the supercharger. What psi is it rated? What CFM does it flow? How fast will it spin? What is the step-up ratio? All of the above are very important factors when you are looking to install a supercharger.
Old Jan 22, 2003 | 01:45 PM
John..'s Avatar
John..
Post
Nice work guys...
Seems like these 928s with positive manifold pressure seem to be coming out of the woodwork these days.
I sure hope George and Carlos are happy now.
Old Jan 22, 2003 | 02:16 PM
Koenig928's Avatar
Koenig928
Post
that picture was too big
Old Jan 22, 2003 | 06:35 PM
UBoatCommander's Avatar
UBoatCommander
Post
The engine at motortuning.com has no A/C. Looks good but a no-go down here in Dallas!
Randy
Old Jan 22, 2003 | 08:28 PM
George 911-V8's Avatar
George 911-V8
From: The Swamp Lands of Louisiana, The Deep Dirty South 2 Miles From Pimp City
Post
John Kuhn: I am pro turbo for the 928.
Curious George
Old Jan 22, 2003 | 09:30 PM
Jim Nowak's Avatar
Jim Nowak
Post
George,
Good to have you on the 928 board. Those 996 turbo guys are not very receptive.
Old Jan 23, 2003 | 01:34 AM
Koenig928's Avatar
Koenig928
Post
I think the Albrex charger setup is very solid. Even thought its quite old now, the charger is a quality built piece, along with the other 'accessory' parts for the engine. The charger assembly did not flex at all when running.
Keep in mind, I bought the car as is, Koenig built motor ~10 yrs ago with the Albrex setup, I dont know if it is the same thing you can buy today. But the picture of that web site looked darn close.
Other stress points I've found on the engine (besides the crank bolt) is the water pump. The 'entire' charger assembly hangs on the front of the water pump, on the three long bolts that normally hold the spark plug wire 'holder'. These threads on the old water pump were starting to break apart.
The charger bracket is made from 12-15mm plate steel, welded together, that peice alone weighs 6 lbs. With everything together (charger, bracket, adapter plate), it all weighs about 26 lbs. Kind of scary when you think about it. But as long as the w.p. and crank bolt are kept 'new', there shouldnt be a problem.
Have not dynoed it yet, but plan to do so.
"is the blower worth it? " well, thats a subjective question. Depends on what you want out of the car. Personally, I love the supercharged engine, its an absolute rush to drive but thats my opinion. I also didnt have to go through the process of installing and sorting the setup...just the problems when its older. You must keep the engine in top shape mechanically,(t-belt, etc, etc) because you are stressing it harder, but it does work extremely well.
As far from that, there are other things that could go wrong, but havent had any of it. Except you'll need rear tires more often!
Old Jan 23, 2003 | 01:40 AM
Koenig928's Avatar
Koenig928
Post
Jim,
Sorry, but I do not have any specs on this charger. Once I get the motor running again, I'll at least see how much boost its making (new boost guage).
If you guys find anything out there, let me know.
Old Jan 23, 2003 | 04:21 AM
elemental's Avatar
elemental
Post
Thanks Bill. If/when I get the blower specs from Gruber I'll post them.
Old Jan 23, 2003 | 12:21 PM
deltaP's Avatar
deltaP
Post
How old is this Albrex setup? could it be the grandaddy of all 928 blower installs?
Old Jan 24, 2003 | 09:19 AM
elemental's Avatar
elemental
Post
<a href="http://www.autoscout24.de/home/index/detail.asp?id=11171251&sc=&make=57&model=1952&pricefrom=&euroto=&zip=" target="_blank">http://www.autoscout24.de/home/index/detail.asp?id=11171251&sc=&make =57&model=1952&pricefrom=&euroto=&zip=</a>
Bill,
Have found another koenig 928 (s4 based?) with compressor for sale in italy. Check out the claimed output ...571hp!!! Original price 115,000 bucks!! Converted by koenig monaco I think. For sale for 26,000 bucks...
Enjoy your car!
Old Jan 24, 2003 | 09:30 AM
elemental's Avatar
elemental
Post
here's a better pic
<img src="http://www.admmilano.com/Images/DB/42.jpg" alt=" - " />
from
<a href="http://www.admmilano.com/" target="_blank">http://www.admmilano.com/</a>
