200A Alternators
Electron Wrangler
To say most alternator shops couldn'y handle it is not too accurate.
Small long time esablished shops may - but chains are programmed for easy work and seem to discourage experimentation (prob due to high return rates).
You can understand that its risky for them especially if you have to modify a case for fit and make up a special cable assembly - then the whole thing is returned because it didn't work...
Nobody ends up happy - see Sharkskins Alt tale - and he had a great shop to work with.
99.9% of people just want the guaranteed plug & play.. and so thats their real business..
Alan
^Gotcha. Just wanted folks to know there is an alternative to the $600 alternator. Carl sells only top quality and his service is second to none. I have frequent flyer miles on his site. For the plug and play guy, he's done all the work and gaurantees it. For the guy who wants to do a little research, there may a local shop that can easily accomadate rebuilding the Bosche. I got a core form my local shark graveyard (It's a sad site to see..
) for $20 and had B&M build a monster for about $300. Still have my stock unit.
As for dual alternators, the kits are on most car audio sites. Hard part is the bracket fabrication to go where the smog pump is.
Sorry Alan, I have been very lazy today, but I am going to get the readings for amperage and voltage that I promised you in just a little bit. I did locate my paperwork on Carls alt and it doesn't give any specific information about it. Pretty much just installation related.
Okay, finally got of my dead butt and took some readings. These readings were all taken COLD. I will post the engine hot readings later.
At idle with radio, 800w amplifier and IPOD on-----Voltage 14.3 Amps---91
At idle with all the above on plus headlights------Voltage 14.2 Amps---86
At idle with all the above plus fog lights and AC with fan on max--Voltage--14.1 Amps--84
Hope this helps
Hope this helps
Electron Wrangler
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Jack - that is excellent info - thanks so much for doing it...
Folks - I like the results shown here so far - the voltage is not quite as high as I feared - and the current capability is very good - interested to see what the hot data looks like too...
Alan
Alan
Alan, tech support from Propower (the alternators builder) told me that this alt will not experience anything near to that 33% loss when hot that I mentioned earlier. They say that this is due to the fact that they use much heavier and more durable internal parts. Should be interesting to see this when I do the engine hot checks. Hope to get to it later today. I will post results here afterwards.
Okay, just got back from a nice little "spirited" drive. I now have the results with the engine hot and auxillary fans running. These are the results..........
Engine idling @800rpm auxillary fans, radio, IPOD and 800watt amp on
14.10 Volts and 94 Amps
With all the above on AND headlights and AC with AC fan on max
Volts-13.62 and Amps-86.50
With all the above AND fog lights....
Volts-13.45 and Amps-84.45
I think I can now put my own mind at ease about having any electrical issues. I am really starting to like this alternator. If there are any other readings you guys would like me to take, just let me know. Damn it's been a rough day, lol, time for a cold beer!!!!
Administrator - "Tyson"
Jack,
Those readings were taken with the meter hooked upto the battery, correct?
Electron Wrangler
Jack - I like the results too...! as our 'all new' Mr Enzo says - exactly how did you measure? - do you have a convenient point for a clamp meter around the Alt wire?
Well - you've just about convinced me I want one of Carls alternators... Like I said I didn't doubt he'd seen good results - I just wanted to see some numbers.
Jack - you must be quite happy with this!
Alan
Alan
Erik, I installed temporary positive and negative wires directly from the battery. They do not go anywhere else. They are installed only because I too was curious how this new and expensive alternator would perform. As I said in an earlier post, The only correct way to see what your alternator is doing is at the battery, since the alternators only job is to keep your battery charged. The more electrical demand you put on your system, the more the alternator need to work to keep the battery charged. Alan, yes, I am very happy with the way this alternator performs and it apparently does not suffer the typical output loss from heat. I was sceptical too. I think I have enough power that I can finally install that beer cooler in the hatch area that I have been lusting for.
Very nice. May indeed be what I need since I may be running a tran oil pump, intercooler pump, and a bigger fuel pump, possibly even a alcohol pump for water/alky injection.
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Originally Posted by Enzo
Atta boy!!!! Still have a little Green Bay in you!!!
Awww, nevermind.![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Awww, nevermind.
Electron Wrangler
Jack - the measurement I'd most like to see would be the direct alternator feed current at the alternator terminal.
The alternators job is actually really two fold - supply all the current to run everthing in the car AND re-charge the battery. If its working well it will be charging the battery and supplying all the rest of the power consumption of the vehicle all the time and the battery will not be supplying anything... (just used for starting).
Worst case should be that the battery isn't getting charged but also isn't being discharged and the alternator is still supplying all the rest of the power consumption for the car.
If you were just monitoring the battery you were only measuring charging current... It is very high in that case? especially sustained... did you have a clamp meter installed around the batt cable?
I guess I'm not clear from your description quite how you measured the current.
The measurement I'm interested in is tricky to do - esp since most 928's alternators have 2 wires - one to the jump post and one to the starter/batt.
I'd want to combine that to a single wire for total output current.
Alan
Alan
