928 Forum 1978-1995
Sponsored by: 928 Specialists
Bridgestone S-03 questions
Old Mar 5, 2003 | 11:46 AM
MikeN's Avatar
MikeN
Post Bridgestone S-03 questions
Anyone running the S-03 tire on 16" wheels?
Sizes I am looking at are the standard S4/GT
sizes of 245/45 and 225/50. However the 245 shows as a "YR" speed rating and the 225 shows as a "WR". Are the two compatible?? All the stats (temp/traction/treadwear) show to be the same. I see that 928 Specialists sells a complete set of them in the 16" size, but looking for some living proof.....
Old Mar 5, 2003 | 12:12 PM
morganabowen's Avatar
morganabowen
Post
Hey Mike,
I would suggest that you go directly to a tire expert, and get the info from the horse's mouth.
The big 3 are all familiar with the tires, or go to <a href="http://www.tirerack.com" target="_blank">www.tirerack.com</a> and they will give you the 411......
Old Mar 6, 2003 | 12:35 PM
Ketchmi's Avatar
Ketchmi
Post
Just for info, the ratings are as follows......
V - 149 mph
Z - 149+ mph
W - 168 mph
Y - 186 mph
Dave
You shouldn't have any problem with the "W" rating mixed with a "Y" rating as both exceed most 928's abilities.
Old Mar 6, 2003 | 01:17 PM
Randy V's Avatar
Randy V
25 Year Member
Post
Just some additional feedback on SO3's in general. I installed 255/45 front and 275/40 rear on my 740iL (18" Rondell 58 wheels - 8.5" front and 10" rear).
A huge improvement in handling. These SO3's grip like crazy and are very quiet. The real test will be how long they last! BTW - I purchased them at COSTCO (special order) at a price that beats Tire Rack.
<img src="http://www.momentoffame.com/snapshots/MomentOfFame/l32019.jpg" alt=" - " />
<img src="http://www.momentoffame.com/snapshots/MomentOfFame/l32020.jpg" alt=" - " />
Old Mar 6, 2003 | 03:56 PM
MikeN's Avatar
MikeN
Post
Thanks for the responses. I actually checked with TireRack before asking the question.....but they pretty much gave the standard response....
"not to mix speed ratings" which I value....but,
I'm thinking that the 245/45 tire is rated slightly higher (YR) just because it is slightly wider with a lower profile then the 225/50(WR). Most likely they are constructed the same way with the same compounds. Any thoughts??
Bridgestone doesn't really look like it has a
tech email or number to call for such matters.
Old Mar 6, 2003 | 11:42 PM
Tommy928's Avatar
Tommy928
Post
I have stock sizes S-03 on my S4 and they work great. The only negative (?) is the 245/45 looks skinny. I would definitely buy them again.
Old Mar 7, 2003 | 08:04 AM
mox's Avatar
mox
Post
My recommendation is not to mix it. Try the So1's porsche approved n2
