Need help removing a split rubber bumper under throttle body
After removing my throttle body I discovered the air inlet tube underneath was loose. It turns out two of the rubber bumper bolts that hold it down had split.
So, how do I get the remainder of the bumper out of the bolt hold it goes into? Left-hand drill bit or have people had success with some other method?
Thanks,
Matt
Thanks,
Matt
![](http://www.bigempire.com/928/rubberbumperpet.jpg)
![](http://www.bigempire.com/928/rubberbumper.jpg)
Originally Posted by touque
dremmel a groove in it so you can use a flat screwdriver...
Glenn
Originally Posted by sharkmeister85
You may not even need to do this. Mine were not very tight. I used a small chisel and hammer and just hit the outer circumference to get it moving. Then it was loose enough to use my fingers to turn it out.
Glenn
Glenn
By the way, on my '85 there are 3 of those bumpers holding the u-tube. I found out they are each a different size and using the wrong size can cause issues re-assembling the intake.
Glenn
Glenn
Good idea Glenn - I actually did the same as you on my old 86 so maybe they have a habit of being loose!
Glenn
Inventor
IIRC, I managed to snap vice grips on the edge, and turn them. Do replace all of them, as the one you didn't replace will break when you reinstall. (Ask me how I know.)
I tried vice grips on the edge, but this looks pretty snug. There is not enough rubber to dremel into to create a slot. A chisel may be the way to go. If that fails, I will get a screwdriver under the metaland bend it upward so I have something to grip with the vice grips.
Thanks for the suggestions.
Matt
928 Engine Re-Re-Rebuild Specialist
If the other methods don't work, clean it off and JBWeld a nut to the top. Pull out your socket and get to work on turning it out.
One of mine came out with the vice grip approach but the other I had to cut two side off with a dremel and a cut off wheel to use an open end wrench on it.
Team Owner
we took a dremel and cut off oppsing sides of the broken standoff studs once there were 2 smooth edges we took a cresent wrench, and clamped onto the the studs they came right out
