928 NLA Parts List
928 NLA Parts List
Thanks to Jim and Mark at 928 International and James Erdmann for the last update on No Longer Available (NLA) 928 parts. Since this list was last published I suspect there must be other parts that are NLA? If you know of any, please list them. Or if you have questions/suggestions for substitute parts. Or, parts that we may want to stockpile just in case they might become NLA soon. As our cars get older, this list will get longer.
H2
113 927 249 – protective cap, spade terminals, horn – 78-91
477 863 747 – retaining clip, rear fender liner, 92-95
900 114 021 01 – shake-proof washer, 70-76 914
901 628 745 20 – vacuum t, central locking and washer system, 78-86
911 606 108 00 – timing mark sender, 83-91
922 424 191 00 – shift plate bracket, 78-86
928 105 125 03 – crank pulley gear, 78-82
928 105 552 02 – tensioner boot (listed as “roller”), 78-82
928 105 570 00 – tensioner arm shoulder bolt, 78-82
928 106 023 18 – “part number cannot be determined”
928 106 277 01 – radiator vent hose, 83-86
928 107 717 03 – oil strainer, 78-86
928 107 722 01 – “part number cannot be determined”
928 110 142 00 – airbox bolt, 78-852
928 110 271 00 – “horseshoe” fuel hose, 83-86
928 110 272 11 – intake tube, 83-86
928 110 272 12 – “parts number unknown”
928 110 272 21 - intake tube, 83-86
928 113 149 00 – diverter valve hose, 78-86
928 201 313 02 – fuel tank strap, 78-82
928 302 026 08 – reverse gear, 78-82
928 333 754 31 – sway bar bushing, 78-82
928 347 085 00 – three-spoke wheel horn pad, 78-82
928 347 449 02 – return line, pump to rack, 78-82
928 347 999 99 – “parts number unknown”
928 351 081 00 – front disc backing plate, 78-82
928 356 019 00 – fuel line to accumulator, 78-82
928 356 021 01 – fuel line from fuel pump, 78-82
928 356 079 00 – fuel hose from fuel filter, 78-86
928 356 081 00 – fuel return hose, 78-86
928 361 032 11 - “parts number unknown”
928 423 185 01 – clutch hard line for 9” brake booster, 78-82
928 424 105 06 – shift ****, manual, 78-82
928 504 029 02 – rear belly pan, 87-95
928 505 005 03 – bumperette, 78-86
928 505 123 21 – rear bumper cover, 87-91
928 511 577 02 – sealing plug, front weather-stripping, 78-86
928 512 277 00 – rear spoiler base, 87-91
928 521 351 03 – seat adjustment switch rose, 83-86
928 521 351 04 - seat adjustment switch rose, 83-86
928 537 403 02 – side molding clip, 78-82
928 537 903 03 – door lock cylinder, 78-82
928 537 910 02 – window regulator, 78-86
928 541 014 03 – windshield, brown tinted, 78-82
928 543 037 03 – left rear window frame, 78-82
928 543 418 02 – left rear side molding, 78-82
928 543 439 04 – connecting piece, rear side window molding, 78-91
928 543 440 04 – connecting piece, rear side window molding, 78-91
928 551 200 00 - “parts number unknown”
928 552 047 04 – center console inlay, 78-82
928 552 047 05 – center console inlay, 78-82
928 552 047 08 – center console inlay, 83-95
928 552 283 02 – shift frame, 78-82
928 555 031 02 - “parts number unknown”
928 555 631 02 – luggage net
928 555 777 03 - “parts number unknown”
928 573 013 02 – evaporator, 78-86
928 573 061 05 – a/c control head, English, 78-82
928 573 077 02 – recirculation flap vacuum valve, 78-82
928 602 904 02 – “parts number could not be determined”
928 602 913 00 – distributor dust cover, 78-86
928 602 933 00 – vacuum advance unit, 78-82
928 606 102 02 – auxiliary air valve, 83-86
928 606 131 00 – lower throttle microswitch, 78-86
928 607 115 00 – engine wiring harness, 83-86
928 609 105 02 – plug boot socket, 78-82
928 612 002 00 – engine wiring harness, 78-82
928 612 002 01 – engine wiring harness, 78-82
928 612 009 00 – battery ground cable
928 612 405 00 – rear harness, 83-91
928 615 111 00 – XVIII relay, 78-82
928 615 123 00 – seat relay, 78-82
928 615 127 00 – headlight relay, 78-82
928 618 109 00 – kick-down relay, 83-86
928 632 105 00 – engine compartment lamp socket, 78-86
928 641 609 05 – central warning light assembly, 78-82
928 641 609 09 - central warning light assembly, 78-82
928 641 701 03 – clock, 78-82
928 641 919 00 – oil/volt gauge, 78-82
928 641 923 00 – PCB for instrument cluster, 78-82
928 641 929 00 – center console light support/frame, 78-82
928 641 953 00 – temp/fuel gauge, 78-82
928 641 973 01 – PCB for instrument cluster, 78-86
928 645 030 00 – manual antenna, 78-82
928 645 211 00 – tweeter, 87-95
928 645 212 00 – mid-range speaker, 87-95
928 645 215 00 – bass speaker, 87-95
928 645 216 00 – bass speaker, 87-95
928 645 402 00 – front speaker, 78-91
928 645 426 00 – rear speaker bezel, 83-95
999 058 001 00 – screw for passenger’s side cover, 87-95
999 137 001 40 – heater hose connector, 78-82
999 239 012 40 – washer hose, 78-82
999 591 487 02 – speed nut for exhaust shield, 78-95
999 689 001 00 – rubber mount, fuel dampener, 78-86
999 703 305 00 – rubber fan mount, 78-82
999 921 004 02 – screw for front spoiler frame, 78-86
Others?
H2
Others?
Speed nut for heat shield, 78-95. NLA? I don't think so. What about superseding Porsche part numbers?
I have never ordered parts directly from a Porsche dealer and was told they are NLA, so I assume if they are listed in the PET without the "U" code they are still available from Porsche.
Some may be in Germany or have longer lead times, but they are probably available.
Cottage Industry Sponsor
I was told the other day that the rain gutter pieces that go from front fender up the A-pillar and along the roof above the door are NLA. And I've also heard that 2 out of 3 used to arrive bent or broken...
In Germany, they said that the side molding piece for the GTS rear quarter panels are NLA.
With the birth of Porsche Classics maybe we need to update this list and pass it on to Porsche. I spoke with my Porsche parts rep today and we are not alone. He has a customer that needs a horn contact switch fixed on an air bag on a 993 or 996 and the only thing Porsche offers is an upgrade to the tune of $2-3k to retrofit a newer version of the steering wheel and airbag.
Basic Sponsor
The whole list will need revamping as many of the parts are in stock again or have been superseded by a new number.
