Would these wheels fit?
Originally Posted by Erling G-P
Incidently, does anyone know if the RH 3.6 wheels my Keskins are emulating can be had with offsets closer to 928 specs ?
The RAL (what I have on my car) is a very nice wheel in a two piece.
Going from a 17" Boxster S wheel with a 55 offset on SXX 225's to the more correct RAL's on 18" 235 PS 2's w/59 offset, there was a noticeable improvement in handling. Partially due to the excellent handling of the PS2's, but also less 'tramlining' than with the 55 offset.
Originally Posted by JPTL
59 front is close enough to specs. to make a noticeable improvement over less offset wheels. The 3.6 style that RH makes are 3 piece, so you'll pay. (RH Wheels US). They make a much less expensive one piece (AG) that looks good on our cars as well.
Cheers,
Erling
Keskin cost 1/3 or 1/4 of what RH list price is. If there is 4-5mm extra material in front wheels which could be removed they would be much better fit.
Cheers,
Erling
Don't think I would even dare contemplate this, for fear of the wheels breaking - which would most likely happen when they're in a high-load situation, meaning you're in even more severe trouble.
