Are there better wiper blade assemblies than stock?
I need a new set of wiper blade assemblies (to be put onto the stock arms that have the spoiler foil to help them hug the windshield at high speed). I keep hearing of new blade material (silicone). Has anyone tried these? Is it worth the extra money? Also Bosch wipers talk a good story. What do you like best? Are stock rubbers and holders from Porsche as good as the modern stuff? Better alternates?
Related question: The special wiper arms with the 'spoiler' are pretty heavy and only installed on the driver's side traditionally (I think?). Would putting these on both sides stress the wiper motor as they are so heavy?
What's your experience?
Thanks,
Harvey
Thanks,
Harvey
Sharkaholic
I like the Bosch micro-edge wipers in full on rain conditions, they do an outstanding job, but in light mist or sprinkles, they suck because they squeak too damn much.
I think the PIAA silicon blades are awesome. They are about the same cost as those Bosch Icon blades, but they age really well, and lay down a layer of silicon which makes water bead on the windshield. I've been very impressed by them when I had them on my other car, I still need to get them for the 928.
Originally Posted by whitefox
I switched to the Bosch Icon blades because at highway speeds and beyond the blades lift.
Glenn
Originally Posted by sharkmeister85
Do they really work? I have an issue with lifting at highway speeds and have never been happy with the add on wings.
Glenn
Glenn
I have used the modern valeo style blades by several manufacturers on the 928. I have not had lifting problems, but have had several torn bladed. Cant say it has happened on the Bosch brand yet though.,
Hans
Hans
Electron Wrangler
The stock GTS wipers have the aero-foil on both sides...
I need wipers that last a long time in the sun. I've had new blades installed that have worn out from sun damage before I've ever used them (talk about a waste of time!....).
What are the votes on longevity in adverse (hot) conditons as well as effectiveness? Seems like votes for Bosch & PIAA on that score already...
Alan
Alan
Glenn
Glenn
Team Owner
if you go to the dealer they can order you GTS wiper arm s and blades, you should be able to find replacement blades but the best thing is the GTS wiper arms have 2 springs instead of one so the arms are stronger and they have a slightly lower profile
Glenn
Glenn
I have excellent luck with the Bosch Micro-edge. Get the whole blade + insert, since yours are likely loose at all of the little pivot points. I've had them last two seasons on a car parked outdoors all the time with no protection -- same set on the shark for 3 years since it lives in a garage by night and a parking garage by day(during the week).
Two little tricks to get the inserts to last a long, long time:
1) When parking the car after using the wipers, lift each arm off the glass and set it back down. When the blades are folded over from friction after use, they tend to take a set. Lifting them allows them to rest perpendicular against the glass.
2) Periodically clean them with a wet towel -- squeeze the blade edge firmly in the towel and pull the whole length of the blade through the towel. Repeat on clean sections of towel until you can do it without leaving a black mark on the towel. Every time I think it's time to replace the blade, cleaning it this way makes it work like new.
Bosch blades are worth the premium. Based on this thread, I'll try Icons or PIAA.
BUT ... RainX Rules, particularly if you travel at night. Not so much in daytime or a well lit city night, but you still have wipers. For those about to head for SITM, try it for the trip and decide.
