928 Forum 1978-1995
Sponsored by: 928 Specialists
vacuum schematic?
Old Jul 19, 2007 | 12:54 AM
mj1pate's Avatar
mj1pate
Default vacuum schematic?
Does anyone have a vacuum schematic for the 85-86 model years?
Also; for the same model years, there is a vacuum hose connecting to the intake manifold that is visible in between/underneath the front manifold tubes. It looks like it may be removable via a long spark plug cable remover type device. Is attempting to remove it risking an unplanned intake manifold removal job?
Thanks;
Mike
Old Jul 19, 2007 | 01:05 AM
silbershark's Avatar
silbershark
Have you performed a search?
Old Jul 19, 2007 | 01:36 AM
Big Dave's Avatar
Big Dave
928 Engine Re-Re-Rebuild Specialist
Ignore the green circle...
Old Jul 19, 2007 | 07:17 AM
mj1pate's Avatar
mj1pate
Thanks Dave...This looks like a diagram from the FWSM. I didn't find a diagram, but obviously missed it. Can you reference the page enumber?
Mike
Old Jul 19, 2007 | 09:45 AM
fabric's Avatar
fabric
24-216 is where iit is for 87 and later, so it's probably just ahead of that, if you don't see a more specific response.
Old Jul 19, 2007 | 09:52 AM
Vilhuer's Avatar
Vilhuer
Could also be in yearly changes documents in Jim's CD's.
Old Jul 19, 2007 | 10:16 AM
Big Dave's Avatar
Big Dave
It's not from the regular manuals...it's from this...
File Type: jpg
Old Jul 19, 2007 | 10:27 AM
mj1pate's Avatar
mj1pate
Thanks again, Dave. I'm wanting to replace as much old vacuum hose as possible, without getting into an involuntary intake tear-down.
Mike
7 Porsche Models That Have Aged Like Fine Wine
Old Jul 19, 2007 | 10:32 AM
Big Dave's Avatar
Big Dave
Be careful when working with the vacuum line to the transmission. Mine had a rubber connector at the front of the torque tube joining the hose from the 7-way connector to the longer hose from the transmission. It's in a difficult spot to access, so when I accidently pulled the engine bay hose out of that connector, I was spewing profanity for about an hour to get it back together.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
