In addition to the brakes. Its also low on power.
7th Gear
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
This post is in addition to the brakes and turn signals post. 83 928S. The engine is also down on power. It has 55000 actual miles,and has been sitting for 2 1\2 years. I.ve added fuel injector cleaner and new plugs but have only drove it for 30 -40 miles, because of the brakelights. It seems to be misfiring at idle and lags at WOT from a dead start. Engine runs smooth at highway speeds. I put a test light on the + side of the coil and it barely would light up with ign. on. Is this because of a resistor on the ignition or could it be a ground? Thanks for any replys.:]
