928 Forum 1978-1995
Sponsored by: 928 Specialists
Aftermarket Ignition Coil?
Old Nov 15, 2002 | 03:39 AM
bcdavis's Avatar
bcdavis
Question Aftermarket Ignition Coil?
My '83 euro (CIS) has what looks like a standard ignition coil. I know with EFI, and with the dual distributor cars, they may have different setups. My question is this: Can I replace the stock coil with an aftermarket one? And if I do, what voltage? They have 34,000v, 40,000v, and 60,000v. Will the stock distributor cap take a higher voltage coil, or would it cause problems? Or just a stronger spark?
Old Nov 16, 2002 | 01:48 AM
checkmate1996's Avatar
checkmate1996
Post
Well, the only thing I know is the porsche manual quotes OEM ignition coils.
Old Nov 18, 2002 | 10:27 AM
Porsche928Driver's Avatar
Porsche928Driver
Post
You can change out the coil. I have a 79 928 and the ignition coil is a Bosch unit. So I put on a MSD Blaster ingition coil. Gives me about 10,000 - 15,000 more volts for spark.
I know it works...I road race my shark and I can feel the difference in the higher RPM range.
Old Nov 18, 2002 | 11:19 AM
Normy's Avatar
Normy
Cool
Wally [generally noted as a "guru" on 928's has said the same as I believe when it comes to coils: Buy the original. First of all, you need what the original requires...this is a computer controlled device and if you mess around with it you are asking for trouble. Second...aftermarket coils, though possibly more powerful, may or may not be more effective. A spark is a spark- in this age of very tight emmision controls, if a stronger spark was REALLY really required for proper emmissions, then Porsche probably would have fit it from the factory. Remember, the ultimate hot-rodders are the factory engineers!
Normy!
'85 S2 5 Speed
