Transmission Replacement Advice Needed
Originally Posted by Vilhuer
This is interesting as another '79 definitelly needed mod between rear seats before S4 automatic fitted in. You are certain gearbox was original S4 and not S3 box coming from S4 car for example?
Originally Posted by telidor99
tarek:
Atlanta GA (Woodstock GA really).
If my acceleration sucks could autotrans be the problem (over a stick?)
Could my 3spd have been worn and a referbed one have better performance?
Could my 4.7 engine have just wore and its not peforming like it did when new?
Could I have a fuel/something else issue?
When my car was running it would accelerate..then hit a hit 45 or so and really accelerate.
What all I have had done (that could be related to the problem of acceleration)
new sparkplugs/wires
new warm regulator (this acutally made a large diffrence in acceleration..was a boat before that)
new fuel distributor
Tun of vac hoses.
few new fuel injector hoses.
A engine leak down (near perfect according to the tech)
lot of seals.
New battery.
Tun of vac hoses.
lot of seals.
New battery.
Originally Posted by G Man
I had an 81' with the three speed and I liked it way more than I like the four speed in my 84'. It just seems like something is not right with it. It drives down the road fine and shifts fine but it just doesn't shift where I would like it to shift. With light throttle It is in fourth by 30mph. I have done the cable adjustment and serviced with fresh fluid and filter.It is still not to my liking. I may send the valve body to Steve C. for a check up. I would find someone with a four speed car you could drive or at least ride in before you go for it.
A friend has a 90 with the lower final drive and it is smoother on the road. If you can pick up an 89 differntial they will fit on the older transmissions and improve drivability quite a bit.
Still give me the 78 five speed with the CIS injection any time. That is the car Porsche intended to build. Very well balanced with the right amount of power for most all situations. Light on the road too.
Dan the Pod Guy
928 Collector
I have an '85 with 200k miles. It starts and shifts down to 1st gear easily and promptly, and as i press the accelerator it shifts very promptly to drop a gear. there are IMHO differences in boxes. but maybe it's all about tuning.
FWIW - it is normal that the US 4.5L auto is a slow starter. Just the way it is. Get to ~40mph in 1st and you've hit the sweet spot of the torque curve when it will really begin to take off. On the opposite end of the spectrum, you should notice the HP drop off at ~5800rpm, even though it'll rev-out to 6200.
Initial health of existing components should always be the first place to look when addressing engine performance. Make sure you have a solid and correctly running foundation before looking to make modifications.
For bottom end - slight bump in timing advance will improve the doggish offline performance, but make sure to not go too far and introduce detonation. IF you don't mind upping gas to plus/super to offset for detonation, you could add a bit more timing lead and get quite a noticeable improvement... albeit at a higher cost for higher octane. Stuck with regular and slight timing bump on The Blue Car due to DD cost of gas and it is at least a nice improvement over stock.
For top end - opening up the exhaust for more flow is said to really wake up the upper rev's (reports from other's only). Entire stock exhaust from manifolds to muffler are known to be restrictive. Lot's of options available.
Personally, the 3sp rocks above 40mph and is really responsive at higher speeds. True, mpg is lower at freeway cruising than a 4sp should be, but once you learn the shift points, you should find performance enjoyable and have no problem playing with the over population of WRX/3-series crowd.
Good luck!!
Good luck!!
