A/C Clutch bearing - 90
I have looked every where trying to find a repalcement bearing for the A/C clutch for a 90 MY. 928 International does not have them. I have tried bearing houses and even A/C shops.
The 90 is different from the 87-89. If any one has a source or wants the specifics contact me directly and I will send off the info.
Dan the Pod Guy
Dan the Pod Guy
Under the Lift
I think this was from NAPA: Ready-Aire 1963 (25211) CL BEARING NIPPONDENSO
This bearing was used in a 1990 928 AC clutch repair. Thinking back, it might have been purchased from a bearing shop in Sunnyvale.
Try Jeff Clark in the parts dept of Sunset Porsche, they have helped me find some tough stuff, including an ABS Harness recently for my shark.
jeffclark@sunsetimports.com
Thanks for the help.
I sourced the bearing at A & W Bearing supply in Texas.
http://www.bearingplace.com/manufactures/ina.html
Cost was about $30. I also ordered some Torque Tube bearings from them.
Dan the Pod Guy
Dan the Pod Guy
