928 Forum 1978-1995
Sponsored by: 928 Specialists
Wenatchee help needed - 928 down
Old 07-06-2007, 10:37 PM
Rod Underwood
Rod Underwood's Avatar
Originally Posted by Jim bailey - 928 International
Mark over the years has created a machine which takes in orders and spits out parts. Some one calls and in a couple of minutes I create an order on the computer and generate a pick ticket. Someone in shipping pulls the part , boxes it , confirms the shipping cost and it comes back to me to charge the credit card (which we do when the part is ready to SHIP ) . Once approved it gets all tracking information and is piled up waiting on UPS/FEDEX pickup that afternoon. All the paperwork is done on the computer which when you have over 45,000 customer contacts in the data base is a MUST. Because we inventory so many parts we ship most orders same day.
I wasn't referring to what you "can" do, but the fact that you actually "do" it.
Rod
Old 07-07-2007, 01:25 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,548 Likes on 1,430 Posts
After fixing the trans cooler you should remove the lower bell housing and check the flex plate, if it is bowed towards the engine chances are good that this motor is going to seize, since it has already given the indication of stalling while hot, Although, not much has been said about what happens when trying to restart the engine while its hot, if it turns over very slow then you will have more info to work from. Dont drive the car untill checking the endplay/flex plate on the rear of the crankshaft
Old 07-07-2007, 04:30 AM
porschepete928
porschepete928's Avatar
thanks guys, the car is getting towed in the morning back to kent...What a weeking this has been .Thanks to jim at 928intl for shipping me the cooler next day air..If someone has time this weeking to see if it has tbf.................thanks again for all your help guys
broke down in no mans land Peter
Old 07-08-2007, 05:50 PM
heinrich
928 Collector
heinrich's Avatar
We looked at the car this morning. John tested end play and it sounds over spec tome but we'll see. The answer is, this is a case of thrust bearing failure.
However:
This must be the best scenario one can imagine. There are very fine shavings in the oil. But practically nothing in the filter. So, I think the engine may have been saved. The clamp/flexplate moved a VERY large distance. I did not measure it, I just saw the aftermath. Either way I think the bullet was just dodged, and John will open her up in the next few weeks and I hope report back.
Old 07-08-2007, 07:01 PM
Andrew Schauer
Andrew Schauer's Avatar
Haven't been on Rennlist for a few days, just saw this thread today...
If anybody in the Wenatchee area ever needs help/place to stay/room to wrench in a situation like this, just PM me. I'll get that quickly, and am more than happy to help.
Quick Reply: Wenatchee help needed - 928 down
