Torque values post motor mount & oil pan gask. replacement
I have successfully completed a motor mount and oil pan gasket exchange for my '90 S4
. This was the most mechanical work I had ever done before. As I am under there I start to ponder the importance of torque values. The step-by-step instructional that I followed to complete this job didn't address the torque values much so I dismissed their importance initially. Back to Rennlist I go after giving it more thought and ran across a few threads about the damage that can result by over/under torquing some critical bolts like lower control arm, steering rack bushings, sway bar, etc.
Although I have been in touch w/ Jim Morehouse regarding the purchase of the WSM, I haven't obtained them yet and I am in need of a few torque values if someone would oblige. I have most of them already so I only need the following:
1. Sway bar bracket to body bolts
2. Sway bar to drop link nut
3. Steering rack w/ bushings to cross member (4 larger bolts)
4. Oil pan plug
5. Cross brace over engine. I realize this must be torqued w/ the car on the ground.
6. Fluid lines at steering rack
Thanks in advance for taking the time to help.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
![nono](https://rennlist.com/forums/graemlins/nono.gif)
4. Oil pan plug
Chronic Tool Dropper
From the little tech-specs book:
1. Sway bar bracket to body bolts: 34 lbs/ft
2. Sway bar to drop link nut: 63 lbs/ft
3. Steering rack w/ bushings to cross member (4 larger bolts): 34 lbs/ft
4. Oil pan plug: 37 lbs/ft
5. Cross brace over engine. I realize this must be torqued w/ the car on the ground. (note-- This must be done --before-- the car is lowered to the ground, especially if you are using a jack and stands rather than a lift to raise the car. There's a serious risk of breaking the windshield if the car body is twisted during the jacking operation with the brace removed.) There is no specific call-out for these bolts, so use the 33 lbs/ft guideline for 10mm bolts.
6. Fluid lines at steering rack: 22 lbs/ft
Also:
Lower control arm - Front bolts: 63 lbs/ft
Lower control arm - Rear bolts: 89 lbs/ft
Also:
Supercharged
Originally Posted by dr bob
Also:
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Thanks dr bob for those specific values and I never realized that about the windshield.
I can see how that could be a factor. I released the cross brace once the engine was jacked w/ stands at four corners. The four holes are slightly out of alignment now w/ the cross brace so lowering the car before installing the brace seems to be my only option. Knowing this about the windshield will certainly weigh heavily on my mind as I lower the car. Therefore, I won't be making any sudden drops and I will be lowering the car as evenly as possible w/ the assistance of a few additional hands.
Regarding torque values for the strut brace I would imagine something between 16 - 33 would be sufficient for its purpose. I'll give 24 a shot and see how it feels on the hand.
Thanks guys for helping me out. I can go button this baby back up now
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
