928 Forum 1978-1995
Sponsored by: 928 Specialists
Looking for a 86.5 steering rack
Old 06-28-2007, 05:05 PM
Iggypop
Iggypop's Avatar
About how long should 86.5 owners set aside to do this job?
Old 06-28-2007, 05:08 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
To remove and replace is about 2 hours "book time" it is really not a big job but it needs an alignment check as well.
Old 06-28-2007, 05:34 PM
SharkSkin
SharkSkin's Avatar
I recommend that you also figure 3-4 quarts ATF to flush the system. Drain it at the return line where it connects to the rack, move the wheel lock-to-lock till it quits draining, then button it up -- fill, cycle lock-to-lock ~10x with engine running, drain, repeat till the fluid coming out looks new. You can keep re-using old crush washers on the return line until you are done, then when you button up that fitting the very last time use new crush washers.
Old 06-28-2007, 05:39 PM
AO
Supercharged
AO's Avatar
'MARK' from Florida said he got one from Autozone with a lifetime warranty. Might want to check them out.
Quick Reply: Looking for a 86.5 steering rack
