928 Forum 1978-1995
Sponsored by: 928 Specialists
At last. Stroker pistons......
Old Aug 15, 2007 | 12:19 AM
  #46
123quattro's Avatar
123quattro
"here" is a hyperlink to JE. Click it. JE makes solid stuff. I'm running Diamond pistons in one of my engines. They were slightly cheaper than JE for a little higher spec piston, but I had to send them back twice for more machining. Wrist pins didn't fit the first time. Second time after I could get the pins in, the rod hit the bottom of the piston. They seem to be mostly set up for American V8 stuff.
Old Aug 15, 2007 | 12:48 AM
  #47
slate blue's Avatar
slate blue
Hey ATB, good to see you are making progress, albeit slow from the sounds of things, wish you all the best with it, can't wait to see a photo of you behind the wheel!
gt37vgt who are you, you never identify yourself in your posts, why don't you introduce yourself.
Greg
Old Aug 16, 2007 | 06:38 PM
  #48
atb's Avatar
atb
Just got the latest info from my machinest.
Bob weight is 1857, not too far off Stan's.
He's adding 170 grams of Mallory to the front and 178 grams to the rear.
He had the crank counterweight marked to show exactly where the Mallory needs to go, but he can't put it all there because the counterweight doesn't have enough room. Instead he said he will load the weight near the leading edge of the counter weight with a portion of the mallory, then respin the crank to determine how much and where to put the balance of the mallory on the trailing side of the mark. Essentially by putting weight on either side of where the mallory is supposed to go, I guess it works out the same. (but with twice the labor).
I'm getting off pretty good here on price. He said only $400 for the crank, and wanted to balanced and index the flywheel for an additional $125. I thought I'd be into it for double, so I said go for it. I'm happy.
Time to start getting the block prepped for its ride to Wisconsin.
Old Aug 16, 2007 | 06:39 PM
  #49
atb's Avatar
atb
Also,
Anyone know where I can get the flywheel dowel pin?
Old Aug 16, 2007 | 06:48 PM
  #50
Vilhuer's Avatar
Vilhuer
Is it solid or rolled piece of flat steel? If solid make it out of suitable diameter drill bit.
Old Aug 16, 2007 | 07:18 PM
  #51
gt37vgt's Avatar
gt37vgt
oo sory Greg hello all I'm from the 944 turbo forum I have a 944 S2 motor in bits and after noticing the corillos give me more crankcase clearencs i'm thinking about a welded up stroker set up so i cam over here looking for stroker threads
Adam
Old Aug 16, 2007 | 09:34 PM
  #52
Stan.Shaw@Excell.Net's Avatar
Thanks Adam, looks like I need to revisit my local machine shop. I checked with another shop and they wanted $225 just to spin the crank. You are 40g lighter though, I think I could save much of that with lighter pins.
Old Aug 17, 2007 | 10:22 AM
  #53
Adam,
Do you have, or can you get the balancing details?
I would be interested in the rod rotational and reciprocating weights, as well as the piston with pin weights? I am presuming our ring, bearing and pin locks are the same or significantly different.
Thanks!
