Replace/Upgrade Power Steering Pump
Originally Posted by griffiths
The spool valve torsion bar or rod is "inside" the spool valve ... inside the splined input shaft.
How about a 110 bar pump?
FWIW, I went to a 13" steering wheel on my S4 and on the track I don't notice any effort in the steering. Of course I'm pumping 130 Bar on my adrenaline meter, I might not notice if my PS belt came off.
As the 'normal' pump output is 70 bar, the 100 - 110 bar range ( which Griffiths suggested) would be an appropiate upgrade.
Shimming the spring should achieve the desired result, but unless one has a test rig to measure the dead head/relief valve pressure, it would be prudent to increase in very small steps.
Originally Posted by SharkSkin
IIRC rack length varied over the years -- if you don't have enough adjustability in your tie rod ends a different rack may require that you replace those.
I put the Griffith's HO pump in the 79 when I changed all the hoses. I noticed a difference at parking lot speeds. (Easier to turn the wheel for sure) About the same at highway speeds which is how I like it.
Jerry,
I would guess your hoses are original at 20 years old. You probably don't HAVE to replace them, but it might be a good thing to do while your in there. (Not that difficult)
BTW, I've got a brand new in the package p. steering resv. for your model year and Need to get rid of it. It might go good with your new pump and hoses!
Chuck, let me figure out if I really want to tackle another project. Right now everything works perfectly on my 928 which is a new experience for me.
I used to live in Plano, twice actually. North of Legacy and south of Legacy.
