A question for Wally (fog/driving lights)
Wally,
This has been posted in another thread, but I afraid that you may not see it there.
I read your response to changing the bulbs in the rear lights on an S4. Are the front fog / driving lights just as easy ? Can I get to everything I need from the front of the car, do I need to remove the nose piece ? I have purchased a new set to replace the scratched, cracked, stone-chipped old ones (entire assembly w/Stongard).
Sorry for the stupid question, but my set of manuals are on semi-permanent back order.
I have ordered the new H3 bulbs from you and can't wait to get them.
Rob <img src="graemlins/jumper.gif" border="0" alt="[jumper]" />
I'm not Wally....
However, the instructions for replacing the Fog Light bulbs are found in the Owners Manual. Haven't had to do this (yet), so I can't tell you how hard it is to do (can't be as hard as a side marker lamp though!).
hth-
hth-
I'm not Wally either:
However, I have replaced the fog and driving light bulbs.
Replacement is fairly easy. Remove the rubber protectors on both sides, then remove the attachment screws for the lens. (NOTE: Do not move the adjustment screws.) Remove the lens, and have at it. YMMV.
