FS: 16X7 phone dials
Anyone interested in some 16X7 65mm offset phone dials for a 928? Three of them are in good shape, straight, no rash, ready for paint or polishing. The fourth one is rashed up pretty bad. I bought these to use two of them for fronts on my 924S, but the offset is too high, and I think the tires would rub on the springs when I turned.
I'm looking to get $150 plus shipping for the set of four.
Thanks,
Dan.
Thanks,
Dan.
i also have a 924s and used similar wheels off my 928. they will work with a 205/55. i tried a 225/50 and they rub on the spring. if you end up stiffning the suspension and go to a smaller diameter front spring i was told then they wont rub.
just a thought
v-tach
just a thought
v-tach
Yeah, I thought about running a smaller tire on front, but I really want to run 225's all around to keep the balance of the car. It understeers in tight auto-x turns as it is with 205's at all four corners. I found a good deal on some 15X7 PD's with the proper offset that I'm going to put some 225/50's on, then throw a 951S sway bar on the rear, and let it slide
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
