Do Engine Sensors Reguire Ground???
Sharks:
I am painting intake manifolds and housings on top of the engine. Most sensors up there have 2 prongs. Do I need to remove the paint at the place on the manifold where the sensors screw down to provide grounds?
Thanks Mike,
Makes sense. Do no 2 pronged sensors need grounds. The Timing Belt Tension Sensor has only one lead going to a carrier, and comes on when the ground is absent.
