Custom camshaft Q
Custom camshaft Q
Hey guys,
With used Euro cams going over a grand has anyone tried having a custom cam ground for the 928. Several companies online will grind any cam you want and have thousands of profiles online...maybe even a 928? At $250 a pop it would be half the cost for the pair and you could even go a little "extra" euro on the grind.
Just thinking I can put my Euro-s cams in the soon to be mine, Non-S. Then I could have new slightly more agressive cams ground for the S engine.
Anyone checked into this yet? Chances are if someone has a set out of the car, they could be used as a "proof"
Originally Posted by Stan.Shaw@Excell.Net
Wouldn't any stock 928 cam require material be added via welding to increase lift or duration?
