928 Forum 1978-1995
Sponsored by: 928 Specialists
Official SHARKTUNER thread
Old Jul 3, 2007 | 08:03 PM
  #76
Vlocity's Avatar
Vlocity
I am still looking for a Shark Tuner to rent or someone within a reasonable distance from West Central Ohio to tune my 85 Twinscrew.
Thanks,
Ken
Old Jul 4, 2007 | 06:02 AM
  #77
John Speake's Avatar
John Speake
There are only 3 LH2.2 adapted SharkTuners in the US at present. NC, NV and OR.
Old Jul 4, 2007 | 09:14 AM
  #78
camboinc's Avatar
camboinc
Andrew Olson tried to hook up his shark tuner to my 87 S4 a couple days ago. The tuner would not power up. It worked fine on Chaad's 88. Don't the 87 and 88's use the same connector? Also, could there be something wrong with my car?
Old Jul 4, 2007 | 09:46 AM
  #79
AO's Avatar
AO
Supercharged
Brian-
#1. I don't have a shark tuner, but if you get boosted... we might have to go halfsies on one. WHat I have is Theo J's diagnostic computer.
#2. I found that although you have the port for the diagnostic hook-up, the early 87LH's do not have the diagnostic capabiliites. Your's must be one of the early ones. Just the luck of the draw I guess.
Old Jul 4, 2007 | 10:47 AM
  #80
camboinc's Avatar
camboinc
Old Jul 4, 2007 | 11:18 AM
  #81
heinrich's Avatar
heinrich
928 Collector
How's that suspension Brian?
Old Jul 4, 2007 | 12:10 PM
  #82
John Speake
To use a diagnostic tool you need to swap the EPROMs in both LH and EZK to MY88 ones. I can supply, or anyone with a SharkTuner can blow a couple of standard chips for you.
Old Jul 4, 2007 | 01:16 PM
  #83
H2's Avatar
H2
From what I read, the closest SharkTuner to you may be in NC? I don't know who has it or if it's optimized for your particular car. I'd hope that Dave R has it and can offer that service.
Harvey
Old Jul 4, 2007 | 01:26 PM
  #84
Giovanni's Avatar
Giovanni
There is one in AL .
Old Jul 4, 2007 | 03:58 PM
  #85
John Speake
...................but not updated for LH2.2 85/86 AFAIK...
Old Jul 20, 2007 | 10:24 AM
  #86
John Speake
Just an upgrade for those interested in SharkTuner developments.
We have made some significant progress on the EZ-F ST option in the last few days. Great work by Niklas. Now we have overcome a rather difficult problem we hope the remaining parts with be relatively straightforward, although time consuming.
I'm looking forward to using this part of the ST on my own 86 Euro S2 :-)
I am reconsidering ways of making the SuperMAF conversion a more cost effective option. At present the conversion is contained within a recalibrated MAF. What I did not recognise with this apporach is that in effect I have created a single sourced but life limited component. I believe from a marketing point of view this was a mistake.
I am proposing to package the SuperMAF electonics in a self contained unit, so that it can then be wired in series between the cars MAF connector and a standard MAF. This then solves the problem of interchangablity of MAFs. Ideally a reclaibrated MAF should be used, but if you are SharkTuning anyway, you can take up the errors in MAF calibration of an older MAF as you tune.
This solution would probably retail at around 150 USD.
The only problem with this approach is the male 6 way MAF connector (like the one on the MAF) which I cannot find a source for at present. I can provide a flying lead with the 6 way female plug to do from the new box to the cars MAF, but the lead in the cars cable form would need to be changed to a newer type of (similar) waterproof Bosch connector.
Would this be acceptable ?
I could provide an adaptor lead to enable the SuperMAF unit to be bypassed if required at any time.
Old Jul 20, 2007 | 11:34 AM
  #87
heinrich's Avatar
heinrich
928 Collector
John IMHO, a new better lead at the harness can be only an improvement, and we should consider creating new components with expensive, rare, inferior older bits ONLY as absolutely necesary. Not much choice at the female (MAF) side, but the new converter unit with better leads would be fine, if not desirable.
Old Jul 20, 2007 | 12:03 PM
  #88
John Speake
Thanks for the useful feedback Heinrich !
Old Jul 20, 2007 | 01:51 PM
  #89
Art_Z's Avatar
Art_Z
would Authority chips already meet that scenario? Iirc, there is only one set of chips sold to cover all years of the S4
Old Jul 20, 2007 | 02:11 PM
  #90
John Speake
The Autothority chips I have seen are based on MY88 and so do have diagnostics.
