GTS engine specs versus S4!
Originally Posted by Boomerang Baba
I do have the original pistons in the block. All GTS spec I believe. Do I still have to drill those holes?
Originally Posted by SwayBar
Those numbers are for cylinder bank 1 - 4. Are you sure the last character is an 'R'? Or is it a '3'?
The car it came from was produced in October 1992 and should be a 93 model then.
https://rennlist.com/forums/928-forum/356382-16-995-93-gts-on-autotrader.html#post4247681
Ok.
What exactly shall I do ones we start to really overhaul the engine?
Any specific information as to how to drill those holes? Once I have everything in bits, any tips on how to get more hp? Porting the tops I guess....! Anything else?
Erkka,
Correct, 1992 first introduction of GTS, however Boomerang Baba gave the engine type as M28/50 which, was first introduced in the European model GTS in 1993 whereas the 1992 GTS had a M28/49 type fitted.
I made a mistake with the valve lifts, inlet lift was 9.5mm changed from 10mm and exhaust lift was 8.5mm changed from 9mm.
I must have been drinking some of your high alcohol beer and not reading correctly. On my first trip to Finland I was drinking your great beer, however, I was getting a little under the weather and I asked for a Light Beer. To my surprise I was getting drunker and when I asked to see what type of light beer I was drinking I discovered that that was its name and it still had the high alcohol content. Heavy head next morning, but that night I was introduced to your Finnish White Wine.
Tails 1990 928 S4 Auto
SwayBar,
You asked for my source of information, 8 years of owning a 928, doing extensive reading and all my own maintenance and repair work, however, most of my technical information comes from Jim Morehouse's Technical CD, the WSMs, Technical Specification booklet, Service Info Tech books and the web.
Hello,
I just verified that it is indeed 271.03 and 273.03 on the side of the cams. So I have GTS block, pistons and cams but what about the valves. Are they interchangeable with S4 valves? The ones we took out of this GTS engine look and measure up exactely like a S4 valve I have lying around...?
Several of the valve lifters are hard as rock so I guess I need to buy new ones to get this engine pakka. They are abou t80 US or so over here. Any cheaper options? The engine has a fair amount of carbon residue on the piston heads and on the valves. I guess we will just have to bring it back to its orignal glory now that we almost for certain know that it is indeed a GTS engine!
Thanks again for the assistance!
Originally Posted by Louie928
Since you have the heads disassembled, don't use the GTS exhaust cams. S4 exhaust cams work better. For even better performance, use GT cams.
http://www.928developments.com/stree...t_packages.htm
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
And one step further: does the GT exhaust cam index properly with the GTS intake cam?
Originally Posted by IcemanG17
Or even better performance get Devek B1 cams like Louie and Tims monsters are running!
Hi,
I do have a complete S4 engine in bits. Mostly in good shape...
Can I just slide those S4 exhaust cams right in with the the rest?
Oh by the way I just delivered my S4 manual `89 to Henrik Fries in Gothenburg to complete the work on the supercharger install! He is going to map it up and install antoher brain...!
I will get it back next week. Should be fun!
His heavily modified `78 racer was in his garage. Impressive work. Screw compressor on a 4,5 liter block. Light weight. Nice.
Alex
I've been wondering about this very question: do you know whether the S4 exhaust cam indexes properly with the GTS intake cam? In other words, can they be mixed and matched and retain their independently stated valve timings?
I wonder how that big cam will run with a smaller 5.0/5.4L engine?
Hi,
Hopefully in few weeks I'll have another early GTS engine to compare. Sadly it has suffered similar block death as my first one. Block has cracked due to head gasket failure. If I'm lucky, crank, heads and seven pistons are all ok.
Another interesting fact - the most wear on the conrod bearings was observed on cylinders 1-5 and not on 2-6. The only barely visible singns of wear on the piston skirts' was observed on cylinders 3-7. The engine had done 20,000 very hard (service on schedule, but pedal to the metal at all times) miles before I bought it.
I do intent to re-use the original Porsche bearings - too many bad stories about Glyco being too tight on this list. I am not so sure about re-using the conrod bolts, but there is a part of me thinking that I will get away with it just once
