928 Forum 1978-1995
Sponsored by: 928 Specialists
Paint question...
Old Jun 14, 2003 | 07:38 PM
glack's Avatar
glack
Post Paint question...
Big chip of paint came off shark last night (don't ask how) the resulting "hole" is about .75" x 2.5" - what should one use to "seal" this up so that water doesn't get under the paint and no more paint comes off?
Any help would be much appreciated!
Old Jun 15, 2003 | 02:20 AM
Rich9928p's Avatar
Rich9928p
Post
Answer to item 2). That screw is the idle speed adjustment screw. So, adjust it so your idle is smooth (650 - 700 RPM) and you're done. You didn't hurt anything.
Old Jun 15, 2003 | 03:15 AM
glack's Avatar
glack
Post
Aha! Thank you Rich.
Old Jun 16, 2003 | 04:18 AM
glack's Avatar
glack
Post
Anyone know whom I can contact about this? The local body shop just tried to sell a paint job..."we wouldn't be able to match the paint, but I can give you a quote for the whole car..."
Uh...yeah.
Old Jun 16, 2003 | 09:42 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Post
If they can't/won't match the paint they are a pretty poor body shop.
If you go to an auto paint/body supply shop (not a body shop, a paint store), they can custom match your paint in your choice of materials. It will be expensive - perhaps $50 for a pint. a quart won't be that much more.
You can use an artists brush to "fill" the hole. Overfill it, then block sand with fine and superfine paper, then buff. It isn't likely that you will get a perfect job, but it will be less noticeable.
Old Jun 16, 2003 | 03:27 PM
glack's Avatar
glack
Post
Wally,
Thanks for the reply. Any insight on the "choice of materials" I should be seeking?
Also, since the metal is exposed, do I need to put down some sort of primer? The primer on my car is a red color.
Thanks again.
Old Jun 18, 2003 | 05:13 PM
glack's Avatar
glack
Post
Anyone know if a paint code is of any use at a shop today - how likely would they be able to match paint using a 18 year old paint code from Porsche?
Old Jun 18, 2003 | 05:51 PM
MikeN's Avatar
MikeN
Post
Yes, a paint code will be valuable to the paint shop. I had a shop mix a pint of custom paint that perfectly matches the silver Porsche uses on their wheels. Didn't think this silver color had it's own paint code, but they printed one on the label when it was done. BTW....I brought in a painted wheel cap as a sample. The results were not absolutely perfect, but much better then any other pre-mixed paint out there. A good idea is to bring in the gas cap door to the paint shop for them to match. They will take the paint code first and then adjust for your cars age, fade, etc. Wally was spot on, it cost $50 bucks.
