One touch window swithches
Originally Posted by Alan
On pre 90 cars its a complete myth - don't hold out for this there is no way it can ever work (no matter what relays are developed...)
There are no real window relays on the pre-90 cars - the "window relay" is really only the power supply to the widows & sunroof - all the motor power goes via the switches in direct drive mode. that why they wear out so often - quite a bit of current to switch.
I started the VW Relay thread (a long long time ago) and it was about Intermittent Wipers....
For wiring see the prevoius thread ... full story of how to make the paragon module work on a 928 is there...
There is also a window development from Rod Kubis in the works - but its been stalled for a while. Rod will eventually get if figured out and that will
provde a good option for <90 cars also...
Alan
Alan
Man of many SIGs
Originally Posted by Normy
No, you did not. I started the thinking regarding the switch- If you plagiarized then more power to you- the people designated as "Captains" and tied to a piling. Lucas gets a big repreive, and some more- wow, he's not used to gun fire! My head is still ringing from the laser blasts!
Dean of Rennlist, "I'm Listening"
Interesting...
If you read Bill Ball's post, there is a statement that the driver's side window will close automatically if you hold down the switch for more than 0.5 seconds.
My driver's side window will not do this. Both windows have the automatic "down" feature, but neither have the automatic "up" feature, no matter how long I press the switch.
I do have the feature of both windows and the sunroof closing when you hold the door key in the "lock" position.
Does anyone have the automatic "close" feature on the driver's side window?
Electron Wrangler
Normy - Whaaat?
Bigs - Yes I have it and so does Andrew and others. ROW/Euro's do this by default - The window controller is the same but has to be configured this way with a plug connection (easy) - your car can do it but default USA is to have this disabled for liablilty reasons.
When configured as a ROW car the driver window only does express-up just like express-down. It also changes the power function so the windows are always active whenever a door is open regardless of ignition switch - this is a great feature - handy if you forget a window or when cleaning the car...
Normy - this is the intermittent wiper post I was referring to - from 2002
https://rennlist.com/forums/showthre...eferrerid=6055
Yes I know you have posted on this window topic since - and I believe I said then it wouldn't work (....and it still wont
Alan
Alan
Supercharged
Bigs-
Here are the instructions, paint-by-number style.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
https://rennlist.com/forums/showpost...4&postcount=36
Originally Posted by Andrew Olson
Bigs-
That looks so simple even a doctor could do it!
Originally Posted by 69gaugeman
Hey hey wait till you do it before giving yourself the credit......
J/K
J/K
That's why I said it looks so simple even a doctor could do it.
Reality may a whole nuther ballgame! You realize, of course, that I will only post results if the outcome is successful! No news is bad news!
Originally Posted by perrys4
I don't know Bigs. You might want a nurse handy to wipe your forhead when this procedure gets tough.
