Turbo II wheels on 88 928 S4?
Will the below wheels fit a 1988 Porsche 928 S4?
Front: 8JX18, offset: 50. Tire size: 225/40ZR18.
Rear: 11JX18, offset: 45. Tire size: 295/30ZR 18
Administrator - "Tyson"
Fit - Yes
Ideal? No
Quite a few people are running those wheels on an S4 with no problems, some have a slight clearance issue with the rear fender.
Ideal? No
From your calculator the wheels I just bought on ebay tonight will not fit on my 88 S4. Looks like my fenders will need to be rolled.
They will fit....not ideal.....the rears will require some rolling...the fronts will drop on.....50mmx 8" rim is about the minimum you should run on a 928.....the bummer is 225 is about the widest tire you can run without rubbing...I have CIII 18" 8x57 front with 235/40 fronts....fit no problem and not rubbing even at full lock @ 155mm ride height
Thanks for the info I will probably have a professional roll the fenders not something I feel comfortable doing. I bought hollow spoke Turbo II wheels should be here next week mounted with pzero's.
