928 Forum 1978-1995
Sponsored by: 928 Specialists
Look what I found in my oil pan...
Old 05-22-2007, 01:11 AM
Big Dave
928 Engine Re-Re-Rebuild Specialist
Big Dave's Avatar
Default Look what I found in my oil pan...
Background -- I'm replacing a cylinder head after mine broke where the chain tensioner was attached. The tensioner was chewed up along with the cam teeth.
First of all, allow me to say that Hondabond (similar to Yamabond) is strong stuff. It took me 20 minutes to pry the oil pan off once all the bolts were removed. Very strong stuff, no leaks. I can't imagine getting the pan off with the engine in the car.
Anyway, I'm still hunting for a missing bolt from the chain tensioner. The pan itself feels like sand when I drag my finger along the bottom of the pan, and the magnet gets an instant afro from all the shavings. Here are pics of some of the bigger pieces...
Next I'll be pulling off the damage head to get a better look at what's still stuck out of sight. I'm also missing the tensioner's oil supply tube.
Old 05-22-2007, 01:14 AM
mark kibort
mark kibort's Avatar
timing tensioner pad?
that otherstuff looks pretty nasty too.
Old 05-22-2007, 01:15 AM
Big Dave
Big Dave's Avatar
Yes, the bottom portion. When the head broke, the tensioner was turned sideways and chewed to hell. The two pieces pictured are the same piece. Looks like it just snapped off in the carnage.
Old 05-22-2007, 01:16 AM
Big Dave
Big Dave's Avatar
If you can believe I feel lucky at all, I'm actually feeling like I got off easy. The timing could have been distrupted so easily!
Old 05-22-2007, 01:20 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
How do you know it happened in that order? Just curious.
Old 05-22-2007, 01:25 AM
Big Dave
Big Dave's Avatar
I don't, and can't, know for sure. The spike-shaped portion was the only part of the bottom pad that came off, and wasn't where the chain normally made contact. I'd post picture, but I donated the tensioner to the 928 Shrine last summer at SIH.
Old 05-22-2007, 01:44 AM
mark kibort
sure looks like the delrin pad took a ride down the sprocket highway!
and my sprockets lost teeth for no reason at all! I still have 2 of them floating around somewhere in the engine! of the 6-7 teeth total lost before i replace the cams with the 85S types.
mk
Old 05-22-2007, 01:50 AM
RyanPerrella
RyanPerrella's Avatar
Dave,
I want to know, what the hell is it that you have those peices sitting on. Its hard to pick out the bits fron that cow hide background. What is that? It looks like some linen colored cloth thats oil soaked in spots. But the spots are evenly spaced somewhat that it seems like its an animal hide or something.
What is that?
Old 05-22-2007, 01:53 AM
JHowell37
JHowell37's Avatar
Originally Posted by RyanPerrella
Dave,
What is that?
It's a hi-res photo of a paper towel.
Old 05-22-2007, 01:55 AM
Kevin Michael
Rocket Pilot
Kevin Michael's Avatar
Ryan, I believe it's a paper towel.
Old 05-22-2007, 02:08 AM
RyanPerrella
ok ok
i was hoping you skinned a cow
Old 05-22-2007, 02:12 AM
Big Dave
Big Dave's Avatar
Yep, blue heavy duty paper towel. Looks like I wiped my car's ***.
Old 05-22-2007, 08:39 AM
Mike Frye
Craic Head
Mike Frye's Avatar
I knew this wasn't going to be easy to watch, but I clicked on it anyway.
Man, that's some serious roughage.
Old 05-22-2007, 10:03 AM
Big Dave
Big Dave's Avatar
Originally Posted by Sterling
I bet the tube is stuck in one of the oil drain back passages, along with the missing tensioner bolt.
Yeah, I suspect that, too. I'm planning on checking each one as best that I can. What are the chances that something like that could be recirculated through the engine?
Old 05-22-2007, 10:11 AM
hacker-pschorr
Very good chance. I'm still finding "debris" in my oil filter from last June's oil pump failure
This after swapping oil pans & rod bearings.
How far down do you plan on tearing apart this motor?
Quick Reply: Look what I found in my oil pan...
