928 Forum 1978-1995
Sponsored by: 928 Specialists
944 pistons for hybrid engine?
Old 05-23-2007 | 02:20 PM
  #31
Scott M.'s Avatar
Scott M.
Rest in Peace
Originally Posted by mark kibort
the pistons are from an 85-86 US. you can tell by the little dish in the middle of the piston. on an S4 it is very large, and hence the reason you can use the S4 pistons for a hybrid motor. this means the heads on an S4 have a lot less CCs. so, an interesting rebuild would be using an 85 block with S4 heads to bump the compression to 12:1. plus you get the larger valves of the S4 heads and by using the 85 cams (same as GT) you get the best performance package of the stock components. I dont think anyone has ever done this yet.
Mk
Give me a few months I've got all the parts lying here just no time to assemble it yet.
Old 05-23-2007 | 04:22 PM
  #32
gruffalo's Avatar
gruffalo
so to sum things up, S4 block and Euro S/S2 heads combined will give a lowish CR, especially when adding the CCs for the necessary piston cut-outs. So to get a proper CR for N/A I will need to shave off the heads. This will make the valves go deeper, requiring even deeper piston cuts.
And there are no known EuroS/S4 hybrids built yet. So I have to figure it all out for myself. Currently I'm more of a shock-replacer than an engine-developer, but hey, how hard can it be? And I have approximately zero spare time. I think I'll go for it!
MM
Old 05-23-2007 | 04:30 PM
  #33
mark kibort's Avatar
mark kibort
i think shaving the heads could effect valve timing( that much) not to metion the valves would be pushing down that much farther now. as it is now, the valve reliefs only allow for about .3" . when a belt skips teeth, the max lift being near .45", causes the valves to hit. I dont think i would want that gap narrowed any further.
best just to change out the pistons to 85s, since you have to cut the valve reliefs anyway. you are talking about a $500 set of pistons, vs doing head work that may or may not do the deed.
mk
MM
Old 05-23-2007 | 05:40 PM
  #34
gruffalo's Avatar
gruffalo
mk
true. The timing could be fixed with adjustable sprockets (extra $$$), but still, I'm not comforable with braking new territory. Someting else is likely to come up.
Old 05-24-2007 | 07:50 AM
  #35
928DK's Avatar
928DK
Originally Posted by Vilhuer
Friend is building engine for Rotrex SC. Reasoning behind using 951 was that they are build for boost. Piston tops are better suited for high temps and possibly piston diameter is more cone shaped that in NA pistons allowing more heat expansion.
Idea of having top 2mm of cylinder bore exposed when mixture is ignited don't sound very wise to me. What happens to then walls if there is even small problems in timing or engine knocks?
Give me a call when that Rotrex is on the car, i have a Rotrex C38-71 that i'm gonna put on my S4(when it gets back), but i'm still considering where the heck to bolt it on .. and how to bolt it on.
Quick Reply: 944 pistons for hybrid engine?
