928 body how strong?
From one of the the few people who has actually cut a 928 shell into about 8 pieces I'll tell you that I was quite impressed with just how over the top the designers went with these things. The little divits made by the spot welders are less then a 1/4 inch but required a 3/8 inch drill bit or larger to completely drill out the spot welds. There are thousands of them throughout the car. Many of the body seams after being spot welded have some sort of structural adhesive/seam sealer applied. Cut out a complete cross-section of a rocker panel and you will find 3 layers of steel and in some places, 4 layers. Currently, my car has a quarter panel removed and a cross-section of the rocker panel removed. It's sitting on the ground with no special braces or anything and the doors open and close just fine. In other words, you can remove a lot of structural support, but because each part is made so well, they have some ability to compensate for parts that are compromised.
In addition to the countless spot welds, multiple layers of heavy gauge steel, and structural glue/seam sealer, all of that stuff they spray in the car for sound deadening adds yet another layer of material providing structural rigidity.
Honestly though, one doesn't need to chop up a car to realize how tough it is. Just pay attention when you get in it. It feels like you're sitting down in a chair that's been bolted to a concrete slab. Can your Honda Accord give you that feeling?
I was flipping through my 911 Buyer's Guide from Motorbooks, and it mentioned the structural rigidity of the 911. It basically stated that Porsche advised body shops to replace the front subframe if it was bent in a collision because it was so strong that it was next to impossible to properly straighten.
Originally Posted by Peter F
I agree that the 928 is strong compared to many other cars.
Still curious how it compares to other sports cars though.
I seem to remember seing something on this but could not find anything searching the forum.
There is the crossmember in the engine compartment so it seems to need extra structure side to side up front.
Rear is probably stronger side to side since no one has developed a crossmember to be used there.
/Peter
/Peter
Originally Posted by V2Rocket_aka944
In fact the 928's are made from recycled uranium from old Soviet missiles. You can crash them into a steel wall at 170MPH and not even have a scratch (you or the car), but the wall will be nowhere to be found. Sharks are completely invincible.
Originally Posted by BrendanC
The body has its strong sections and its softer sections. The regular steel in the fenders (rear) and the fire wall seem very soft to me, and a bit less stiff than today's cars, but the rails, and the boxy areas that run from front to rear seem very strong, stronger then the boxed rails in my modern cars.
Received 1,638 Likes
I drag out this old quote from around 1990 whenever this subject comes up:
That is all I need to know
Originally Posted by CarAndDriver
A fifteen-year-old California boy who stole and crashed a 1987 Porsche 928S, later told an officer, "I had it as fast as it would go, and I wasn't letting off." The officer estimated the car was traveling "about 200 mph" at the time of the accident. When the Porsche left the road, it flew 65 to 75 yards, knocked down a pine tree, sliced neatly through two mature cedar trees -ten feet above the ground- and concluded its flight by leveling a maple tree with an eighteen-inch trunk. Examining the wreckage, a reporter for the Anne Arundel County Sun spotted the nearby remains of a compact-disc player and the Bon Jovi CD "Slippery When Wet", whose last track is "Wild in the Streets."
Location: Live Music Capital of the World - Austin, Texas
Originally Posted by Rick Carter
In Cannonball Run II they tried to crush a 928 with Bigfoot, the monster truck not Sasquatch. IIRC they had to cut the pillars before it would crush.
I lost my 89GT to an accident. To make a long story short, I crashed into a previous accident at about 45 MPH. The front of my car was pushed back to the front of the engine. That's about 18" of Porsche stuff compressed and disintigrated to nothing all against the front of the block and water pump. Well both doors opened and closed normally. The windshield didn't even crack. To me they are VERY strong.
Jim Mayzurk
93 GTS 5-spd
Jim Mayzurk
93 GTS 5-spd
Yes Jim BUT the door gap is a little off !
The crush zone worked very well which we see all the time with the HUNDREDS of cars we have taken apart.
I think you are looking for a measure called torsional rigidty, measured in ft/lbs per degree of twist produced, or Nm/degree. Most frequently quoted by makers when they increase the stiffness of a model....dont know it for any specific makes, but it should be findable.
A couple of times when I have had all 4 corners on stands I have found one corner not really sitting on its stand, just being held up by the other 3.
jp 83 Euro S AT 50k.
Another way at looking at how strong the 928 frames are is how well they hold up over time-mileage....look at how many 928's are on the road with well over 100K miles and not a single squeek-rattle......that speaks volumes about strength.....I've driven 1 year old cars that squeek-rattle 1000% more than my 928!
Either way the car did not settle down after days in the air on the fourth corner.
(had to add a thin pcs of wood to compensate)
/Peter
The front end is the weakest link BY DESIGN in a big shunt the engine gets pushed down under the car. The motor mount ears on the block shear off ,the bell housing breaks and the engine starts going under the car. When we buy a car at a salvage auction it comes with a branded salvage title and maybe 1 out of 100 will get "saved". We are in the parts business and that is what we do best ! We do not fix cars do not service cars we sell parts ! and lots of them
If you jack up the car using the front suspension front bracket on the frame and put jack stands under the forward jack points,what you find is that when you release the jack then pump it back up there is some flex as you start to lift from the suspension the body does not come off the jack stands until you raise the jack a bit. Almost nothing in life is "solid"/ rigid there is always some degree of flex. Late model 911s (996/997) hard the ONLY option is to buy a new body shell and transfer ALL the parts because the force of the impact bends the entire chassis ! Porsche engineered the 928 to be stiff enough to do the intended task any stiffer would have needed to be HEAVIER and weight is the enemy ! The A shaped door opening and flying buttress rear panels creates a Very strong roof and I have never seen a roof crushed on a 928 even when someone was creative enough to get one upside down !
