Climate Control Blower Motor
My blower motor quit. I replaced the resistor pack (one of the resistor coils was melted ) thinking it would fix the problem.
No go.
I've checked the fuse. I know that the 88S4 uses the same relay for different circuits. Can I switch out a relay from something else to the blower motor to determine if the relay is at fault?
No go.
Electron Wrangler
Try moving the AC head slider to the DEF position - fan should go to max check you have power at the motor connector (or at the resistor pack).
Alan
Alan
