kempf tool
Does anyone know...can I use the kempf tool to check t- belt tension on my 1993 gts or do I need the $400 plus shop tool noted in the wsm.Thank you for any advice
Andy
Andy
Basic Sponsor
Kemph tool is fine
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Kemph tool is just a copy of the WSM recommended 9131 tool. It's probably more accurate in repeatability than the more expensive 9201 tool.
Problem is some don't read the included instructions, or follow the procedure in the WSM for orientation of the cams and rotation following incremental adjustment:
Tighten adjuster,
turn engine two turns clockwise,
Check,
repeat as necessary.
Tighten, Check just doesn't work right.
Tighten adjuster,
Check,
Basic Sponsor
I have a number of the Kemph tools and agree with Borland that they are more accurate than the factory 9201 tool that I also have.
Where I do not agree with Borland is the procedure "Tighten, Check just doesn't work right" for a simple tension check.
I have done a lot of TB replacements and retentions and in every case until recently followed the factory procedure and in every case have found no difference whatsoever between the first reading and the last.
I now follow the procedure for a new TB simply because the belt has not been turned and positioned/tensioned equally around the rollers & gears and rotating the engine does this.
On a retention check and minor adjustment I do not believe it is required based on experience.
If you have to make a major change at the retention check you need to find out why before proceeding any further.
Each to there own.
Each to there own.
The timing belt is slightly elastic. Turning the engine over after the adjustment, and before the check, permits the belt tension to equalize over the entire length of the belt.
Rest in Peace
