RennSpeed Racing - New products, new prices - check it out!
Set to Full-Auto
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
First up, I have a couple new products - those of you familiar with the hatch pins will recognize the first one.
http://www.rennspeedracing.com/ss_hood_pins.html
It's of the same construction as the hatch pin as far as machining and material. It replaces the factory hood hold-down pin that is nasty looking with a shiney new stainless one that will never rust.
The second thing is not that big of a deal, but still wanted to throw it out there.
http://www.rennspeedracing.com/tshirts.html
I had some t-shirts made for myself to wear to track events/meets so people could identify me as that guy from RennSpeed. I made a whole bunch of them to get the price down and they turned out better than I could have imagined! Testarossa_td did the artwork, every where I go I get compliments on the design.
Also, I changed the we I manufacture my various stainless studs - for the better. I was able to put together a tool to broach the hex key on the lathe as well as began using a different stock size..........what this all means is that I was able to eliminate a lot of time and waste material. This makes it less expensive for me to manufacture, and I am passing those savings strait on to you. I have also phased-out the non-broached studs. I didn't have very many left in-stock and now that it's just as easy to produce the broached ones........they became obsolete.
http://www.rennspeedracing.com/ss_exhaust_studs.html
http://www.rennspeedracing.com/ss_manifold_stud.html
I need some more studs Dan, but this instead is for the intake side of the 32V head. Should I send some sampes?
Mike Simard has some ideas on Stud manufacturing for our engines Dan. He suggests less thread, and a smooth body where there is the most stress.
Could you make these, or is the heat treating just too much work?
Set to Full-Auto
The whole reason for stainless is so it does not rust. Carbon steel IS stronger, but since the torque value for exhaust nuts is 15ft-lbs, it is not a problem in the least bit.........
