Ride height question...
Supercharged
Let's say I want to increase the ride height by 10mm. Would I raise the threaded adjuster by the same amount? I gues I'm asking is there a 1:1 relationship?
Supercharged
Originally Posted by Hacker-Pschorr
Why do you want to raise it?
on Thursday.LF 148 | RF 153
LR 161 | RR 162
I think the rear is okay, but want the fronts at 163.
I started cranking up the LF thinking I needed to raise it 15mm, but then started wondering if it's a 1:1. Thanks to Zeus's linkage, it's a 2:1 relationship. 1mm of adjuster travel results in 2mm of ride height.
Rennlist is Awesome!
It's not 1:1. I think I found 1:1.5, but it depends on your springs to some extent. Use 1:2 and see if that's enough.
I agree with raising the front. No more bottoming and I feel the handling is better in the mid-160s.
It's a bit too low in front and I'm going in for an alignment... I mean Doctors appointment
on Thursday.
on Thursday.
