928 Forum 1978-1995
Sponsored by: 928 Specialists
Busted power steering pressure line!!!
Old 04-25-2007, 02:42 PM
Charley B
Charley B's Avatar
Brian, I have a wrap kit if you want me to run it out to you, but like Mark says, their not dependable on a high pressure p/s hose. The safest bet would be to cut about a half inch each side of the leak and insert a double barb connector and clamp good each side. We can do that in 10 minutes and you're safely on your way.
Did you order the stock S4 hose, or did you order the GTS hose?
Old 04-25-2007, 04:03 PM
jetrainor
jetrainor's Avatar
Just finished re and reing my power steering return line which runs over the driver side wheel well....wasnt able to order the part...back ordered....so we came up with a half inch to quarter inch reduction hose wrapped in stainless steel caging which allows the hose to bend without kinking. Wish i knew how to post pics.
87 euro auto
Old 04-25-2007, 04:46 PM
928SS
Road Warrior
928SS's Avatar
Originally Posted by IcemanG17
I got quotes from local shops from $65 & up depending on what needs to be done.....vs $195 for the new one....I dunno..... I guess I should see how much of a PITA it is to take it off 1st.....I was afraid of a fire too...which is why I stopped tracking the car.....worse case scenario it burst and burned on the way home which is an "accident"...then the insurance would pay for sure...vs ??? on the track?
mine did start a fire when it broke - so don't screw around w/it...
Quick Reply: Busted power steering pressure line!!!
