***Official 928 Dyno & Performance Bragging Thread***
Supercharged
Originally Posted by Tony
I cant locate my 12.4 /14 mile time slip ...just have to take my word.
Since these runs i upgraded to a bigger bosch fuel pump. I just got a Super MAF last week...im shopping for 42lbs injectors and will give it SharkTune eventually. All in all its running pretty damn good for a 160k plus car.
BTW, can you send/post your g-Tech files? I'd like to have a few other cars to compare against -- I think you and I are pretty closely matched.
Captain Obvious
Super User
Super User
Originally Posted by Tim Murphy
5 posts in and the rules have already been broken.
Must include hard data within your post. Something like this:
BTW, if you look close you can see I lifted before I got to the Qtr mile mark on runs 2 and 3.
Sorry I tought that the figures from an actual run were sufficient. I have the actuall time slip at home but not at work. Will take a picture and post it later on tonight. The time data from that run is accurate but to prove it, I will post the slip.
Originally Posted by Louie928
Can 928 owners with N/A engines post runs too? This is corrected to Standard Temp & Pressure (STP).
https://rennlist.com/forums/attachme...d=187348&stc=1
In all seriousness, that is an awesome looking dyno sheet, congratulations! I know you put a ton of effort into making that happen
Here is my best dyno sheet from about 3 years ago. This is from my 5spd car and I really haven't done anything to it since then. Based on the roughness of the curves and the power falling off up stairs you can see I'm having some issues. I'm hoping to get to it within the next month or so. Hopefully with a little tuning I can close some ground on you but those are some pretty lofty numbers.
Supercharged
So I guess your's is bigger than mine. But what was it that Dan said, you can hit both sides of the tuna can, just not the other end!
Inventor
My 130K '86.5 auto with clone chips/mixed chips/stock chips.
SAE correcton takes roughly 10 HP/TQ away at my power levels.
No, with numbers like that you are not allowed to play in our sandbox... go home
If we factor in cubic $ per hp, you are way ahead. Maybe....
Originally Posted by IcemanG17
Okay I'm breaking the rules (since I've never dyno'd my car)....
Louie that is AWESOME.....plus the intake looks SWEET....WOW....your gonna hit 700chp soon!! amazing
Tim,
I have a shelf in the basement filled with boxes of R&D parts and engine parts.
Mife wife asked me the other day; "what in the heck do you have in all those boxes?" I told her "religion".
Administrator - "Tyson"
Originally Posted by Andrew Olson
Holy Horsepower Batman! That's huge! With the sharktuner + FMU I would think you can do some pretty cool things there... 600?
I thought Dan was looking at you when he said that
600 rwhp is the goal for my 5 spd and yes I think it is very achievable.
My goal for my wifes car is 500 rwhp, which I also think is achievable. If I cannot get the car to 500 then I am going to **** can the Stage 3 project because in my opinion the cost and complexity to get the car past the 400 rwhp mark to only make an extra 50 rwhp isn't worth it.
Here is a Stage One Dyno
Supercharged
600 would be nice Tim. I'm sure you'll get there. Personally, I'd love to see 475. DR thinks it's there, just need to spend some quality time with a SharkTuner at a Dyno shop.
Here's a virtual drag rage between your ***** and mine (I got thoroughly spanked!)
Captain Obvious
Super User
Super User
Can you input just the raw 1/4 mile data and have the G-tech software run a simulated comparison against an actual G-tech run?
Supercharged
BTW (unrelated to the above), I just learned that when i dyno'd the car I had the guy hooking up the boost sensor to before the intercooler which will result in a reading .5 - .7 psi higher than actual boost. My datalog said I made 7.1psi which is probably more accurate.
