A Replacement for a NLA Fuel Line
928 Collector
It's really clear to me that in time (not a lot of it even) a straight hose bent to 180 degrees, will collapse. The only nitigator IMHO would be a noncorroding insert that holds the hose shape and I.D. from the inside. It is my plan to go with a steel hose there.
I used Carl's high pressure hose on the u-shaped hose and it works perfectly. I'll see if I can take a picture of it later today. It seems the bend radius soothes out a little bid with the heat and fuel pressure going through it , can anyone confirm it this is true?
Developer
Roger if the alloy engine expands so much that the timing belt "detensioner" must reduce the tension then it is safe to assume that the heads which are on a 90 degree angle would also stress a hard line or the injectors if that were how the two injector rails were attached. The early cars 80-84 use hard line (on the front) BUT the injectors each have rubber hoses which is NOT how the 85-95 injectors are mounted. For the same reasons the intake manifolds ALL use rubber somewhere in the design to allow for the growth of the engine when hot.
Basic Sponsor
Jim,
I think you are saying that the hose was made in that way to absorb movement.
So my thought process is good and a rigid pipe would not be the way to go.
H,
Maybe you are refereing to an all metal flexible hose. A SS convoluted core with a SS braid pressure thrust restraint. Now on that subject I know a lot more as I sold them for years in the Aerospace industry. My first concern would be the min bend rad and IIRC a 5/16"/9mm would not cut it.
The end fitting is a combination of welding and swaging and may restrict the length of available flexible hose.
I will look and see what is available these days.
On your point about the collapse of the rubber/PTFE type hose. The hose is made up of several different layers of material for this very purpose and is designed to stay in the designed condition at a defined temperature, working-proof and burst pressure at a min bend rad.
No concerns there as long as you are within those defined parameters.
The hoses I take of cars are brittle with age and not deformed.
H,
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
doesnt that hose have a hard plastic shell around it?
Most often its that outer shell that apears cracked and dammaged..not the hose internally. The stock hoses are VERYtough, they were actually VERY hard to remove from the stock fittings when i did all mine...but hey, they are VERY old none the less. Replacing them with what ever means is a good idea!
Carl,
This is great! Hey, by any chance are you offering this same service for the high pressure oil lines too? Or could you in the future? I know Kevin would be very interested. We need to do that for the five speed.
Hope you are well!
Leslie
Hope you are well!
Leslie
I had the "pinching" problem when I went to get this fuel line replaced. When we tried to re-create the same bend radius (with the same length EFI hose), it pinched. We did look into some spiral bindings that go around the hose to keep its shape. They look like slinkys. I gave up and went with braid. They kept their shape and are protected from damage. I ended up replacing all my rubber fuel in braid.
Developer
Good idea!
Basic Sponsor
Mike - AKA Byrdman454,
Which car is that hose from? The end fittings have a lot of rigid pipe and therefor restrict the bend rad of the hose.
thanks,
Roger
thanks,
Roger
Craic Head
Carl,
Thanks for adding yet another option to those of us who want to drive our cars forever. Your company is a pleasure to deal with and when I get in there for the rest of my intake refurb I'll definitely be sending these out to you.
