16V twin screw SC?
#31
Originally Posted by Hacker-Pschorr
Then it's running MAF and not L-Jet......
I've thought about doing this. Maybe in the future I'll drop the L-jet system or switch to an adapted system like this.
I'll be switching my 79 CIS to either the EuroS EFI system or an aftermarket setup such as autronic before I add any boost.
#32
Administrator - "Tyson"
How would what have to be changed?
Can I buy a vowel?
Can I buy a vowel?
#33
Can I buy a vowel?
Can I buy a vowel?
and how much do you think it would cost?
#34
Originally Posted by ceedee
sorry, the l-jet. to modify it to a MAF, what is necessary to make it work?
So, assuming I'm not missing anything here, not very expensive. Could be a pain to get working if you don't know what you were doing.
#35
Man of many SIGs
I believe its only $339 + the MAF. It used to be cheaper. I don't know if that includes the MAF or not.
Its the PSC1-009 Pro. Sig. Cal. AFM to MAF HV Output . www.splitsecond.com
#36
![](http://i74.photobucket.com/albums/i258/ceedeefl/928-Engine-on-stand.jpg)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#38
Originally Posted by a4sfed928
I've looked at this site and I can't read it but I thought he was running approx 9psi from the MAP log. Do you know if he increased the boost from what the MAP log shows? I have an AutoRotor that I'm installing on a 1980 16V and I'm having trouble finding injectors that fit the stock rail.
#39
Originally Posted by Ian928
As far as I know he used the car on track several times with 16psi and no IC.
Was he trying to blow it up? I'm suprised it lasted that long.
#40
#42
Originally Posted by JEC_31
Back on the original topic, is anybody planning on mounting a twinscrew to a 16v motor?
#43
#45
Inventor
Cool stuff on that SE OB.
![](http://my928.kicks-***.org/Fries/Startpicture/big/1141934711~Kompressor_motor.jpg)
