928 Forum 1978-1995
Sponsored by: 928 Specialists
Stereo Upgrade Suggestions
Old 03-22-2007, 12:08 AM
JPTL
JPTL's Avatar
That Nak. is very nice, and probably the most consistent with the look of our interior.
Old 03-22-2007, 12:10 AM
Alan
Electron Wrangler
Alan's Avatar
Bob,
I would not recommend a CD changer at this point and even a CD player may be becomming less relevant. In just a few years CD's will be neither the primary sales or transport media and you'll have another dinosaur...
You might consider an MP3 controller player that interfaces to an iPod or can play some kind of remote loadable memory media itself (Memory Stick/SDCARD/HD).
It's possible your current head unit has provisions for an Aux input and this might work well with an MP3 player (though the transport controls would still be on the MP3 player). Or see if you can add on a Satellite or possibly even HD radio unit via the same method..
If you think everything sounds fine except bass maybe you'd do best to add a self powered bass tube or a small amp with low pass filtering to drive say a door mounted sub. I don't really personally like the 'bazooka' type bass tubes but many have used them and it would solve your bass issue (where to put it though).
The problem with loosing the stock amplifer and speakers to add better bass is that its pretty burns much your whole budget (and is a giant pain) to do just that with high quality components and you'd still need head unit for the features you want.
Alan
Old 03-22-2007, 12:25 AM
JPTL
JPTL's Avatar
Alan,
Very good point re: CD changers/players becoming obsolete. It seems like most newer head units have a direct accessory plugin on the face.
As far as connecting an MP3, iPod, or XM/Sirius via Aux. (RCA) connections, that's a great option if the head unit has the capability.
I've found with my Blau. that the AUX input doesn't have the same output as the built in CD player at the same volume. This likely changes from unit to unit, and may have some bearing on the device's line out signal being pretty low.
Also, when the device is powered via an accessory circuit (a permanent install as opposed to battery op. portable uses) the line-in may create a ground loop, and an annoying ignition hum will be present without a noise suppressor/ground loop filter.
Bob, as far as inexpensive solutions to more bass, follow Gary Knox's thread
Old 03-22-2007, 12:32 AM
Shark Attack
Shark Attack's Avatar
I understand you want good sound. But with the engine rumble and road noise can you really justify spending that much on a head? the 928 does not have great speaker enclosures nor is it an ideal listening enviroment. I can see maybe the Nakamichi. I don't think the sound quality differance is as drastic as it was in the 70's and 80's as it is today, no?
Originally Posted by Air Cooled Carrera
Funny I was thinking about this same subject over the past few days (cabin fever). I was thinking the Nakamichi CD 400, CD 500 or maybe go extreme and get the Clarion DRZ9255.
Descriptions
The CD400 has all the ingredients for great sound quality including the 24 Bit and 4V Pre out, it also has an aux input for the Ipod although it's drawback is no MP3 controls which I really want....$320.00
The CD 500 has all the same features as the CD400 but a few more options including the MP3 playback and 9 color choices for illumination but still no MP3 controls..........$400.00
The Clarion DRZ9255 has the 4V preouts, a copper case, DSP!, 4 Built In Crossovers, MP3 Controls and two Aux Inputs and I think it will look perfect in the sharks dash.........now the downside $740.00
Here's a shot of the Nakamichi and Clarion
Old 03-22-2007, 02:36 AM
Optimator
Optimator's Avatar
Alan
I agree. For entry level prices, you can now get a head unit that will play MP3's from a USB flash drive that you plug into a USB socket on the front of the unit. Flash drives are very small and pretty inexpensive. Seems like most can hold at least 1Gb.
Another solution for more bass would be a subwoofer mounted in the spare tire well.
If Nakamichi comes out with a unit that has the aforementioned USB input, I would probably buy it. I like the clean black styling and the ergonomically grouped buttons. Seems like most head units from more mainstream brands are so gaudy looking that they would look bad in any car, IMHO.
Old 03-22-2007, 09:04 AM
Marine Blue
Marine Blue's Avatar
I ended up picking those three for sound quality and appearance. Optimator is right, many newer decks are so over the top and I just can't get past this.
The Nak 400 is an excellent solution although as many mention it doesn't have the built in MP3 controls which I believe are critical considering the direction music is going in.
Slightly off topic.....my wife just bought me a Nano not too long ago and looking back I wonder now why I waited so long to get one. It holds all of my favorite songs from the past 20 years and still has room for new songs! Best part is no silly carying case or the need to change CD's while driving. I highly recommend any type of MP3 player as an alternative to CD's especially if you're looking at changing your head unit in the car.
Old 03-22-2007, 09:06 AM
Marine Blue
One of the major reasons I like the Clarion is the combination of sound quality, appearance and capability. The fact that it has built in crossovers and MP3 built in controls means less external equipment and wiring which reduces the installation price.
Old 03-22-2007, 09:12 AM
Shark Attack
true dat, An octopus in the car is ugly. they are valid reasons to spend it
Old 03-22-2007, 10:09 AM
hans14914
hans14914's Avatar
If you like the clarion posted above, it is an anniversary edition of an earlier piece, the drx9255. The original 9255 can be found on ebay for less than $300, and is one of the best head units ever made. One of my favorite 928 head units is the alpine 7949, they are cheap, clean, and have many options for expansion.
Hans
Old 03-22-2007, 10:20 AM
Ed Hughes
Ed Hughes's Avatar
Originally Posted by edco
I replaced mine with a Blaupunkt Laguna CD35 from SW Stereo in New Jersey; he sells a nice little wiring harness adapter so you use the original amp. It sounds fine and the price is right. I paid $169.00 last June and that price included delivery.
I've got this same setup at Matt. It sounds great, and Stefan @ SW Stereo knows our cars. As Matt mentions, his plug-in adaptor makes the install absolutely painless, and it takes all of 1/2 hour. Before I put this in, I thought either my amp was non-functional, and my speakers were toast. I like good sound, but I guess I outgrew my need to blast at 120 decibels.
I did upgrade my exhaust to about 105db, so maybe that takes priority nowdays?
Old 03-22-2007, 04:35 PM
tdelarm
928 Addict
tdelarm's Avatar
Location: IN BETWEEN A FROZEN CONCOCTION AND INDECISION
BOB!...didn't think you'd want it so I kept it
Old 03-22-2007, 05:11 PM
cobalt
cobalt's Avatar
Received 1,945 Likes on 1,177 Posts
I have the Nak CD500. Excellent unit looks very stock like the CD400 and I have an auxiliary input for my Ipod. Although you need to control the songs via the Ipod. True 24 bit Sound quality is A+ and I use the built in 47W x 4 to power the primary speakers. I picked up a Soundstream amp used off Ebay to power the 6" Mid bass in the rear . It could use a little more bass for driving with open windows but for the money you can't go wrong.
Old 03-22-2007, 07:16 PM
Marine Blue
Anthony have you had any reliability issues with the Nak and were there any particular features in the CD500 which made it worth buying with comparison to the 400? Can you take a picture of the headunit as installed? I'm curious if it sits flush.....
Old 03-22-2007, 11:16 PM
bobbigham
bobbigham's Avatar
Right Tim...I hope that was a paste job......the current stereo could not run that....really, right!!!
I'm thinking very hard hard about the nakamichi unit, i like the look, upgrade the rear speakers and or add a small sub woofer in the back for bass....
Thanks for the ideas and suggestions...I know I need to think about MP3 more and CD less, but I want a unit that will take a CD too.
Old 03-22-2007, 11:40 PM
tdelarm
928 Addict
tdelarm's Avatar
HAHAHAH...ya BOB...just razzing ya...like the car on the beach shot...photoshop!
CD's will be around for a while longer I'd suspect but I'd seriously consider MP3 options...they can handle a huge amount of data, no CD's to lug around and sound just as nice. IPOD is another option. When I had the car I was considering a DVD/GPS set up, new amps and speakers with the intent of keeping everything I pulled from the car in storage.
I had considered putting a 10' bass in the rear wheel storage but i wasn't happy about losing the spare...which probably wouldn't fit anyways. (should check that out)
Quick Reply: Stereo Upgrade Suggestions
