Adding headers/exhaust to SC = less HP?
After doing research and talking with Woody & Louie Ott I have come to the conclusion that adding headers and 2 1/2" exhaust to my Twin Screwed 86.5 would probably yield no additional HP due to overlap and back pressure. Has anyone installed headers and exhaust systems to a SC'd 928 with good results?
Headers and exhaust are worth 20 rwhp on a NA GT; any gains made while NA will be reflected moreso on a supercharged engine. There are literally hundreds of dyno's from other cars supporting this principle.
boy I hope it works cause that is my plan...I have the devek level2 headers and am waiting for the exhaust. then by late summer the dr supercharger should be here and hear comes an easy 460 rwhp...oh baby!
Captain Obvious
Super User
Super User
My past experience with superchaged engines makes me beleive that a supercharged engine needs a very free flowing exhaust, the freer the better. With a N/A engine there is a limit of how much free flow is good and anyting above it is too much.
Swaybar,
I don't think I misunderstood. I was on the phone with Louis Ott for an hour. (Thanks Louie) His website is www.performance928.com Woody lost HP when he installed his headers and 3" exhaust. He had to install restrictors to try and regain what he lost. I think the problem is the compressed air from the SC is blowing through the heads too fast due to intake and exhaust overlap with not enough backpressure. With a NA engine the lack of backpressure is not as much of a factor because the air is not being forced into the heads.
I can see their point, bigger is not alway better!
I just wonder how far away from optimum valve overlap (for a SC set-up) till you end up blowing too much of your fuel out of the exhaust valves. I guess a person could always just throw on bigger injectors till the lean condition went away, but at what cost, HP/TQ?
Swaybar,
Quote:
Lets expand on the carb'd and port injected cars, how much error does the valve overlap and subsequent pre-combustion air add to the overall a/f. What I am saying, does any air pass directly thru from valve-to-valve which is not part of the combustion process.
Answer:
Usually the error is very small to not measureable. The whole point is to make use of resonances with as little loss as possible. The only time I have seen appreciable errors is on supercharged engines where an aftermarket supercharger was bolted onto an engine with a cam designed for n/a. Because with a supercharger there is no exhaust pressure buildup like on a turbo, there is appreciable blowthrough during valve overlap with a n/a cam. This not only causes boost loss during overlap, but also much increased fuel consumption because of the blowthrough.
Answer:
Possibly on low boost SC engines freeing up the exhaust flow would help similar to the way it does on NA engines. And I'm sure that on higher boost engines having a too restricted exhaust isn't good either. There is probably an optimum point between exhaust back pressure and boost, and cam overlap. Right now, I don't know what it is. Bigger may not always better, for exhaust at least.
Nope, Charles didn't misunderstand. Louis was ready to build a 3" system for my SC'd GT and his engine analyzer program doodad showed minimal gain for a lot of work. I have the Devek headers and we are going to install them on my NA GT, there just wasn't enough payback to do the work on the SC'd GT.
Jim
Jim
Interesting information to say the least.
Let me think about this.
Administrator - "Tyson"
Looks like I might have to be the Guinea pig on this one. This is my new plan of attack suggested by Loius Ott. I already know I have 372 RWHP & 354 RWTQ with 6 psi boost, no intercooler, stock headers, Ott X-pipe, stock 2 1/4" exhaust & 928 Spec RMB. I plan on installing my Devek Level II 1 3/4" primaries to 3" collector headers. I'm going to reduce the 3" to 2 1/2" and custom fab a Burns stainless 2 1/2" X-pipe and install my stock 2 1/4" exhaust with the RMB. I'll put it on a Dyno and see what I get. While at the dyno I'll see if they will let me unbolt the stock exhaust after the X to see if I lose power or gain power without the 2 1/4" restriction. Any suggestions are appreciated. Any donations for this test are welcome too! Ha! Ha!
Supercharged
Fascinating read! I wonder if this is why more than a few of us with boosted engines have commented that a catless X-pipe combined with an RMB produces less power (measured via 0-60 & 1/4 miles times) than with the stock rear muffler!
Good question. It makes sense, I think.
Originally Posted by Vlocity
Would there be any advantage that you can see to retarding the timing at the cam?
Originally Posted by Hacker-Pschorr
Just curious - does anyone have the flow characteristics of the stock exhaust manifolds? Wouldn't this be needed for an accurate "before" number? Or is entering in the pipe size / length etc..... good enough for an accurate comparison? Again, I'm not trying to question Louis's data, just curious how this process works.
It may not be dead on accurate, but change a system parameter and a trend will show. On a NA engine you can change primary diameter and length, collector diameter and length and see changes in the output. For the stock exhaust you can use primary dia of 1.625", length as 8", and collector length as 24" which is about average until the pipes from both sides merge. Then change primary length to 29" (keep the dia at 1.625") and collector length to 10". Leave the rest of the exhaust as it was. You'll see an increase in power. Do the same with a SC engine and there won't be much of a change.
