928 Forum 1978-1995
Sponsored by: 928 Specialists
Bondage (engine case sealing/bonding - RV)
Old 03-15-2007, 11:33 PM
BrianG
BrianG's Avatar
Mark, have you ever disassembled cases that were assembled with 518? I hear it's a bear!
Old 03-16-2007, 12:35 AM
mark kibort
mark kibort's Avatar
yes, this was the engine that locked up when the "old" rings dug in to the cylinder walls before it even fired over!! it wasnt bad at all. just a puddy knife and some scotch bright and a razor blade to clean it all off. however, now i KNOW, why the WSM says install the oil pump and bolt half it in, and the attach the two halves, then torque the halves and then remove the oil pump. if you leave the oil pump in and not pull it out after assembly, the redline glues the oil pump to the block. i fouind out the hard way, when the oil pump wouldnt turn. after pulling it, i was able to scrape all the locktite off and it is fine now, but close call!
MK
Old 03-16-2007, 03:07 AM
Fogey1
Fogey1's Avatar
Bus wrote: "I use the permatex products on a lot of other automotive stuff, and as a superthin smear on gaskets to make them come apart better in the future. My 928 oil pan is sealed with black permatex... with the right technique, it's wonderful. Learned the technique at a Dodge dealer in the early nineties, and when I worked in Cummins for tech support, we had a tube of thier sealer on every workorder...."
Hey Bus,
<MORE> on "the right techniques" please.
Old 03-16-2007, 06:05 AM
Fastest928
Fastest928's Avatar
Yamabond or threebond.....
Old 03-16-2007, 11:53 AM
BrianG
BrianG's Avatar
Thanks Mark........ each of these brands has a number of products...
Old 03-16-2007, 10:46 PM
BrianG
BrianG's Avatar
WTF??? Nobody is carrying Loctite products any more.... It's all Permatex!
I wanted to try 518, and I don't see a Permatex equivalent. Any ideas of the Permatex 518 equivalent?
Old 04-13-2007, 12:42 AM
918-S
918-S's Avatar
I have Locktite 574 as recomended in the WSM. It's expensive but worth it. I cross referenced the chemicals on the MSDS sheets with permatex and it's not the same.
Quick Reply: Bondage (engine case sealing/bonding - RV)
