Piston Squirters ?????????
Originally Posted by atb
Orifice at top of pic.
That's it. One per cylider. They share a common passageway to the main bearing journals. The journals have oil ports which are closed off by a small valve, it may even be just a ball bearing, which seals close due to spring pressure. When the oil pressure in the mains get high enough to overpower the spring (4 bar), the valve/ball bearing collapses the supporting spring and oil rushes into the port, through the passageways in the block, and out the orifices. In theory anyway.
Although I haven't looked for myself, I've been told that I have a squirter under my hood. I did have to put rod bearings on the car with only 75k on the odometer, but I'm chalking that up to someone using an oil additive that was built up in the bottom of my pan. My serial number on the car is #125 and a build of June 1986. I can't remember what my engine vin was.
