928 Forum 1978-1995
Sponsored by: 928 Specialists
Loose Airbox Straps? Ultimate Solution (IMHO)
Old 02-19-2007, 10:19 PM
sharkmeister85
sharkmeister85's Avatar
Default Loose Airbox Straps? Ultimate Solution (IMHO)
Hi All!
I was never entirely happy with other solutions I've seen proposed. I preferred to keep the original straps for their non-obtrusive, stock look, but didn't want to pay whats seems like big $$$ for new ones (like who does?). How to take up the slack and get a tighter fit though, without cutting, other fasteners, etc.
I came across some some foam insulating tape in the garage that I had left over. It was 3/8" thick by 3/4" wide closed cell neoprene with an adhesive back. I measured up 4 lenghts of about 7 1/4" to attach to the top half of the filter box under each strap. It seems to have worked, taking up the slack and making for a very snug fit. Best of all, I think it blends well with the box and original straps.
I'm not too sure how these pics turned out and posting them is not something I have much experience with, so please bear with me if this doesn't work as intended.
The first pic is my stock air filter box
The second is the insulating tape I used
Next the strips attached
And 2 shots of the finished look
Old 02-19-2007, 10:21 PM
ErnestSw
ErnestSw's Avatar
Nice job!
Old 02-19-2007, 10:24 PM
sharkmeister85
Thanks Ernest! Did I mention it was cheap and easy to do (like 10mins. I already had the box off the car though).
Glenn
Old 02-19-2007, 10:25 PM
heinrich
928 Collector
heinrich's Avatar
Dude I still have your plug end
Old 02-19-2007, 10:27 PM
sharkmeister85
Good! I was worried some postie had snapped it up.
Glenn
Old 02-19-2007, 11:13 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Nice but keep an eye on it casue that foam is not rated for high heat and it might age very fast.
I did something very simmilar, instead of the foam tape I used several layers of "magic wrap". It looks like an electrical tape but its made of raw rubber or something and can strech and stick really well.
Here is a quick pic I found on Google. http://www.glasgowmfg.com/pages/magicwrap.html
Old 02-20-2007, 12:01 AM
G Man
G Man's Avatar
Good Idea. I used another method for mine. Don't think my fix will work on your air box. Unless the little tabs are hidden under the strap.
The four rubber straps on my air box are useless. They are intact, but there is no life left in them and they are stretched out. The solution for me was to go to the local Napa and buy a bag of tire chain tensioners. Cost $4.50. Took about ten minutes to install. Just take off the hooks and put on the air box. The fit is nice and tight. Hope this helps someone out.
Old 02-20-2007, 12:54 PM
mark kibort
mark kibort's Avatar
i like the "chain" straps!! nice idea!!
i added a bead of silicon on both sides of the filter. let is partially dry and then compress it with the straps on the car. it makes a form fitting seal that also takes up the slack of the old straps.
this also solves the leaking air box issue that most all 928s have under WOT.
mk
Old 02-20-2007, 01:36 PM
Marine Blue
Marine Blue's Avatar
Some great ideas, may have to try one of these this spring.
I've noted very small hairline cracks in the rubber of my straps, anyone else note this? If yes has the extra stretching by adding material underneath the straps caused breakage?
Old 02-20-2007, 02:37 PM
sharkmeister85
G Man,
I like your solution and was going to use it, but I didn't have those lugs on my air box!
Afshin,
I don't have the hairline cracks on my straps (yet!), but I would expect my solution will add more strain to the straps and make the cracks worse over time.
Glenn
Old 02-21-2007, 10:17 PM
Panzer9
Panzer9's Avatar
I did the same thing but back to front w/ 7/16" x 1" closed cell adhesive backed. Fits exactly between the small "rails" on top of the airbox. Really snugs up the straps ,and squeezes the filter between top & bottom. Good suggestion!
Old 04-18-2012, 09:35 PM
PC-85-928S
PC-85-928S's Avatar
Did this today
One of the best fixes I found via Reinnlist search
$5.00= tight air box, plus you can't even see the weatherstripping!
Old 04-19-2012, 12:25 AM
SanDiego928
SanDiego928's Avatar
mk
something new learned, didn't know about WOT issue, i will have to check that out.
Old 04-19-2012, 12:38 AM
MainePorsche
MainePorsche's Avatar
mk
My straps are fine, but have audible air box leak at WOT.
Excellent tip. Will also help when my straps loosen.
Thanks Mark
Old 04-19-2012, 01:06 AM
mark kibort
Thanks Mark
no problem. i have messed with the air box for years and years. i actually was able to get a pressure reading difference of near 1/2 " Hg by the old method and the sealed method. proved that there was some major leaking under WOT .not that its a huge diff, but its something.
Quick Reply: Loose Airbox Straps? Ultimate Solution (IMHO)
