so i did try to change my differential oil
#31
Originally Posted by Mrmerlin
hey if you cant get the plug loose try getting a torch and heating the surrounding area you might see smoke from the drain plug but after heating then try using the the short allen key if that doesnt work then go the hit the plug on the side with the hammer/chisel this should breake it free
#32
Schocki's way to do it. The problem is that there is no room to for a socket plus ratchet or breaker bar.
That's a good way how to save some room. Extending the wrench is also easy and you can use a dead blow hammer for the initial movement. I use the hammer to tap the open end of the wrench, this normally works very well.
#33
Administrator - "Tyson"
I think a lot of people who put these back in do not understand the theory behind pipe threads. The torque on this plug is something like 15ft-lbs IIRC.
#35
I bought a 17mm allen 1/2 drive socket at Auto Zone. OEM brand, came in a 3 pack and was inexpensive. The really fun part is getting the sticky goo into the fill hole while laying on your back. Fuel hose attached to bottle won't work. They make a funnel with a line attached, however, the tip won't allow it to fit into the fill hole deep enough. Cut it, but not too short so that when you over-fill the funnel it all pours out because you have to hold it at an angle. In the end, out of 2 quarts I got 1/2 in.
#37
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Oh yeah, when you try the fuel hose method, don't poke a hole in bottom of bottle because you think that it will aid in the flow of the sticky goo, through the hose that is.
#39
Originally Posted by marton
HTML Code:
Paul posted In the end, out of 2 quarts I got 1/2 in.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Marton
how many quarts do i have to get in again????
#40
I drilled a hole in my battery box right by the fill plug. Works like a charm.
#43
DON'T spill any fluid in the hatch. Gear oil stinks!
#45
Ed Hugues said: " I suppose that would work but IMO that kind of thinking and project completion is what has decreased the value of many 928...sorry but thats my perception. Thats just another form of deferred maintenance.
Heinrich said: I have to agree with Ed.
Guys, I think that if any owner was to complete the job this way then I would have to agree with you. But I'm trying in my minds eye at least since I don't know Ceedee, or you Ed, or you Heinrich that the object in the immediate is to get this young fella's transmission working again with AS LITTLE DAMAGE AS POSSIBLE in performing this very simple service. If we ever meet I think you'd come to the conclusion pretty quick that there not much shadetree about me at all.
What I've seen over and over again are lots of guys on different vehicles getting into trouble performing a manual service in their driveway. On a half dozen occasions I've had to go out to help somebody in these situations and the goal to me is to get the vehicle mobile. I've always felt its better to drive then tow. In this case I would have the customer fill up the transmission and then BRING it to me to remove the checkplug. All of the suggestions here, although helpful and would provide insight to someone less knowledgable could also do alot of damage to an aluminum checkplug/transmission in the hands of somebody less experienced.
Thats the area of concern here for me at least is that that the casing gets cracked. If you think you got problems now. Anyway thats the context to which I answered the question, I hope that if you don't agree with me at least you understand my reasoning.
Mark
Mark
