Tranny pan gasket
When replacing the transmission pan gasket, do you have to "activate" it the same way you would when installing a new oil filter?
If you are a 4 speed , check out some posts by 'nails' re a gasket change by MB that Porsche did NOT pick up. Old style gasket was prone to fail around the middle bolt on the side.
jp 83 Euro S AT 50k
jp 83 Euro S AT 50k
I hope that this attachment will help.
I usually fit gasket dry, so that the ridges hold on the sealing surface. Do not over torque the pan set bolt.
Tails 1990 928S4 Auto
Its a MB number, however, in the PET it is also designated by this MB number. The part number is also stamped onto the pan gasket.
I have found that purchasing the pan gaslet from MB or European Part Suppliers is cosiderably cheaper that from an OPC. I carry a spare gasket in my garage.
