How do you get the door lock out?
I have the door mechanism out but I want to get the inner locking mechanism out of that piece so I can get it powder coated. How do I get the inner locking mechanism out?
This is the point I have it at:
ther is a small brass pin driven through the the casting and into the tumbler it will be hard to find with the paint so sanding will reveil the pin location then drill a small hole next to pin so drilled hole exposes side of brass pin then you will have to pry it out. or bring it to locksmith thel probably do same but there is no scews or removable hardware just the stupid pin
