I played around with mine and tried all the adjustment tricks I could find listed...but the plastic insert was buggered a bit and it would never reliably lock/unlock. So, after several years, I finally caved and bought the receiver piece new, with new plastic insert and it's worked perfectly ever since for me. Seems like an obscene amount of money but you may have few choices.
From: Gliese 581g | Monte-Carlo, Côte d’Azur, La Planète Terre
I have the same problem at the moment. Come to think of it; it happened the same way you describe. I just wake up one morning and the hatch will not latch! On mine, the white plastic thing was broken in two pieces. ...This calls for a new hatch release. Probably the same for you I am guessing.
Check all of the previous and good suggestions. If still not latching, latch could be stuck in the unlock position. Try turning key to the lock position. If it clicks, latch was stuck and it should close properly. I have ran into this several times.
