Turn signal/wiper switch removal
My turn signal switch will not stay in the on position when turning right so I need to remove it to fix it. Has anyone removed theirs and can give me a dis-assembly proceedure please.Do I need to remove the steering wheel or will the switch assembly just come straight off by itself?
pull steering wheel
lift instrument pod upward to clear
loosen the clamp that is part of the stalk unit and grips the shaft
unplug the rear-mounted switch sockets
pull
Disassembly:
Drill out the rivets
catch all the little parts carefully
pull
Disassembly:
Originally Posted by heinrich
by the way, apologies for my American accent
Just don't let that happen again. I heard my English wife say "Trash" the other day instead of "Bin" - I asked "What, you think you can just lose the English wording and still be married to me?"
I'm sure your wife knows that English expression, try it on her sometime
Neil
Dayum
you mean I gotta pull the steering wheel ? bet I haven't got anything big enough to loosen the boss . rummages in toolbox.
I know what is going to happen lol I'll get the bits off then think `well now I'm here I might as well just strip and refurbish the pod' then it will be the complete dash in bits all over the house. groan....
I might just `distress' it a bit instead. Thats English for hit it with a big hammer.
Originally Posted by JP Rodkey
Yup, wheel has to come off because the switch is clamped around the steering shaft. Socket is 27mm, but a 1 1/16" will work fine (IIRC).
BTDT, still have the socket. But I don't know if 17/16 Whitworth works.
