TIMMING BELT Q
TIMMING BELT Q
I am a little confused. I have a 928 service manual & in the sectin about checking the timming belt tension, there are 2 different tools used. A 9131 & a 9201. There is no explaination for the application of which tool to use. I see that the HTD belt is used on '83 models & up. Are these 2 different tools specific for the type of belt in your car?
Rob
Rob
Chronic Tool Dropper
The 'original' 9131 checking tool was the one with the spring. No longer available. Later cars were treated to the one with the dial. One of the better Rennlisters has started to mfr a replacement for both, in the spring style. It only works for the 928 timing belt however; the 9201 will test other Porsches (944/968) and also the alternator belt on the 928, fwiw.
You can order the Kempf tool from 928 International (and other places) for about 10% of the new cost of that 9201. It's a lot easier to use too.
If you post your location, somebody nearby might be willing to loan you the tool and maybe even help with the tension check. It's been known to happen in my neighborhood and in others around the country. Otherwise it's cheap enough (<$100 last time I looked) to own your own, especially if you do your own work on the car.
Much thanks Bob! I may try this myself. Seems easy enough. I am rather handy & like working on my own rides. any tips about this you can give me? My car is a true '84 Euro.
Thanks!
Thanks!
These links from one of the many TB threads.
Pirtle's guide , Tom928's nice writeup on some 16V stuff, the 928int guide, Bill's guide, the sharkbit guide, 928 specialists kit
