1982 3spd auto....When key is on but car not running, I depress the gas pedal and trans solenoid does not click until I am just about to the floor. Should that be right or should it be like 3/4 throttle before it clicks? How can I adjust if not correct?
Sounds absolutely fine. The hardest part after kickdown activation is to keep your foot o it. Your natural tendency will be to slightly let go after activation and to cancel the kickdown.
