928 Forum 1978-1995
Sponsored by: 928 Specialists
Torque setting for crank?
Old Jan 21, 2007 | 12:40 PM
Tampa 928s's Avatar
Tampa 928s
Default Torque setting for crank?
Is it 229 Ft lb's ?
Old Jan 21, 2007 | 12:56 PM
Garth S's Avatar
Garth S
Originally Posted by Tampa 928s
Is it 229 Ft lb's ?
218 IIRC .... but whose to quibble over 10 - 11 ft.lbs?
Old Jan 21, 2007 | 01:02 PM
Mike Frye's Avatar
Mike Frye
Craic Head
I used the info from Bill Ball's Timing Belt Resources page:
Torque Values in Ft-lbs:
Crank 218
Cam gear 47
Oil Pump Gear ?
Oil hose fitting to radiator side tank 52 – be careful to counter hold inside fitting,
Water pump bolt (M6) 6
Other M8 bolts (13mm head) 15
Other M10 bolts (17mm head) 30
Old Jan 21, 2007 | 02:07 PM
the flyin' scotsman's Avatar
the flyin' scotsman
The WSM lists:
